dsl not connected and speed issues
- dsl not connected and speed issues
Re: dsl not connected and speed issues
20-06-2009 7:02 PM
20-06-2009 7:14 PM
21-06-2009 10:10 AM
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,416
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 18.0 / 31.0
SN Margin (Up/Down) [dB]: 22.0 / 15.5
FEC Errors (Up/Down): 0 / 115,432
CRC Errors (Up/Down): 0 / 50
HEC Errors (Up/Down): 0 / 44
can someone please explain what these errors mean ?
21-06-2009 10:21 AM
Regarding the sync speed can you post the noise margin graph from Routerstats for the over night period
21-06-2009 10:35 AM
Just to confirm it has peaked at 16.0 and gone down to 12.0 at the moment it is 15.0
21-06-2009 10:47 AM
If you save the picture as a jpg then you can post it on here using the Additional Options Tag
21-06-2009 10:49 AM
21-06-2009 10:53 AM
21-06-2009 11:02 AM
However it does look as though the sync held at a good rate.
Does the log show anything happening yesterday evening (Routerstats or the router itself)
EDIT - I am a bit unhappy with what happened at about 22.00
21-06-2009 11:16 AM
21-06-2009 11:25 AM
The noise margin gross variation over night is what would be expected although the small continuous variations are a little higher than I would have expected that is probably down to the router and is nothing to be concerned about.
All we need to do now is to wait for the silly BT system to respond and then for Plusnet to update their system.
The easiest way to find out when it happens is to check the Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed
21-06-2009 11:31 AM
Telephone number:
Phone exchange:
CONNAHS QUAY
Estimated line speed:
4.0 Mbps - Checked on 2009-04-04 17:29:32
Current line speed:
2000
21-06-2009 11:35 AM
21-06-2009 2:43 PM
21-06-2009 3:24 PM
