dsl not connected and speed issues
- dsl not connected and speed issues
Re: dsl not connected and speed issues
16-06-2009 7:55 PM
Remove the orange/orange white pair from terminals 3 and 4.
Can you confirm that the cable going down the wall is the one attached to the faceplate and the other cable is the BT incoming cable.
16-06-2009 7:58 PM
16-06-2009 8:01 PM
16-06-2009 8:11 PM
16-06-2009 8:15 PM
16-06-2009 8:16 PM
url=http://www.mybroadbandspeed.co.uk][/url]
16-06-2009 8:17 PM
16-06-2009 8:18 PM
Output Power (Up/Down) [dBm]: 11.5 / 18.0
Line Attenuation (Up/Down) [dB]: 19.0 / 34.0
SN Margin (Up/Down) [dB]: 21.0 / 15.5
16-06-2009 8:20 PM
Can you unplug all the phones and see if it changes. If it reduces can you plug them back in one at a time to see which ones cause the problem
16-06-2009 8:21 PM
16-06-2009 8:26 PM
SN Margin (Up/Down) [dB]: 21.0 / 16.0
16-06-2009 8:30 PM
The reason is that last night we were getting these results
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,776
Line Attenuation (Up/Down) [dB]: 18.0 / 31.0
SN Margin (Up/Down) [dB]: 21.0 / 15.0
whereas we are now getting this
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,112
Note the major drop in speed
Edit - with that attenuation you should be getting speeds well over 4000kbps even with a 15dB noise margin and the only reason you have such a high noise margin is instability on the line
16-06-2009 8:32 PM
it is a thomson tg585 v7
16-06-2009 8:39 PM
However with that router you can do it from the web interface I believe
Go to Broadband Connection page and you should see this
16-06-2009 8:45 PM
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,176
SN Margin (Up/Down) [dB]: 20.0 / 15.5
