drj - speed problem split off
- drj - speed problem split off
Re: drj - speed problem split off
11-01-2012 9:07 PM
11-01-2012 9:08 PM
I have similar attenuation and with my router a near a possible to the master socket and other tweaks to the phone wiring i get
Uptime: 0 days, 12:25:41
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 820 / 5,792
Bandwidth (Up/Down) [kbps/kbps]: 440 / 5,752
Data Transferred (Sent/Received) [MB/GB]: 117.25 / 1.58
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 20.5 / 42.0
SN Margin (Up/Down) [dB]: 18.0 / 8.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 77 / 0
FEC Errors (Up/Down): 178,125 / 537,431
CRC Errors (Up/Down): 2,566 / 4,470
HEC Errors (Up/Down): 19 / 73,647
To be is to do - Kant
do be do be do - Sinatra
11-01-2012 9:25 PM
Thank you all for trying to help but (a) I don't understand what those protocols are (b) after looking them up I'm hardly any wiser and (c) I think around 2.0 DOWN and 0.5 UP is potentially what I'm supposed to be getting anyway. I can't explain the initially low UP figure apart from as the historical figures show it varies.
I initially responded in a different topic where someone was switched from ADSL to ADSL+ - hence the first line of my apparent OP. The point at issue was whether switching to a different "flavour" of ADSL was (a) possible and (b) likely to be beneficial or not considering the wide spread of possible speeds being quoted by the speed checker.
Alternatively I realise my router is very old (in computer terms) since it was built in 2004 - it was a cast off from my brother which came free - including the set-up! Would I gain any speed if I switched to a more modern router? The problem at present is really only stuttering videos - otherwise it's fast enough.
Presently I'm probably just going to put everything back where it was but use the replacement extension - the original has a broken plug in any case. I can't leave things where they are because I'm presently having to step over the router and being on the floor where it is will probably limit my wireless range when I use the laptop.
11-01-2012 9:46 PM
the attenuation after the migration actually went down marginally and the speed went up
11-01-2012 9:51 PM
11-01-2012 10:10 PM
12-01-2012 8:35 AM
Quote The wire comes into the kitchen downstairs where there's an old style master socket - then there's a hard wired extension up to the living room upstairs
I wonder if the ring wire is connected. You're not really supposed to interfere with fixed wiring but is it possible to carefully unscrew the faceplate from the extension and see how many wires are connected. If its only 2 then its fine, but if its 3 or more then potentially that could be part of the problem.
12-01-2012 1:31 PM
You're on ADSL1 on 21CN The SNR is currently 13dB, so that will be keeping the sync rate down. Let me know if you get to the bottom of your wiring issues. Once you have I will look at resetting the SNR. There's no point doing it at the moment because it will only go back up again.
Jojo
12-01-2012 6:00 PM
Quote from: MisterW
My understanding of telephony isn't much more than my meagre understanding of Broadband connections.
However I've taken the faceplate off to find all six wires connected - and very neatly it's all done too. I have no reason to think it wasn't done by BT - it was certainly over 15 years ago.
Wouldn't the "ring" wire need to be connected in any case to make telephones plugged into that socket ring?
12-01-2012 6:05 PM
Quote from: drj Wouldn't the "ring" wire need to be connected in any case to make telephones plugged into that socket ring?
Yes - if your telephone looks something like this with an actual bell inside.
Otherwise - no!
See http://www.kitz.co.uk/adsl/socket.htm
12-01-2012 6:07 PM
12-01-2012 6:21 PM
Quote from: Joanne You're on ADSL1 on 21CN The SNR is currently 13dB, so that will be keeping the sync rate down. Let me know if you get to the bottom of your wiring issues. Once you have I will look at resetting the SNR. There's no point doing it at the moment because it will only go back up again.
Thank you. Unfortunately my understanding of connections is pretty poor - so I don't really know what I'm looking for. As I've said when I put the new extension back into the circuit last night following plugging the router directly into the master socket with everything else disconnected, my speed test result actually improved although the router figures went down slightly. So I'm not sure what I should be looking for. Or how looking at the figures my router advises, how I can tell if any alteration is beneficial or not.
Please advise - is there an "idiot's guide" to all this terminology and the implications somewhere at PlusNet or elsewhere?
My initial question was actually a follow on to another person's asking about different ASDL connections - this one - please note you haven't indicated whether a switch is likely to be beneficial or not - or even possible. Or have I got to try and work out why the wiring I've been using for 12 years (though only two using this router - quite a few previously on USB Broadband modem) is suddenly not acceptable?
12-01-2012 6:26 PM
I do know I was originally on 1MB with Orange and about 3 years ago they sent me a letter saying they were upping my speed to 3MB - I surmise that might have been the change point? I'm about 2 miles (crow flies) from the Gloucester exchange.
12-01-2012 6:27 PM
12-01-2012 6:29 PM
