draytek vigor 120 & airport extreme
- Re: draytek vigor 120 & airport extreme
16-05-2012 1:59 PM
hi all
decided to get airport extreme & a draytek vigor 120 modem for my plusnet service as wifi from the supplied v8 thompson & technicolor one is not great & load of interference from surrounding houses/dect/microwaves etc.
so anyhow, plugged in airport ex. to my technicolor & wifi worked fantastic! phones & ipad far far better as its on the 5ghz freq. happy days.
vigor 120 turned up today, plugged in & no internet as yet, anyone any ideas? do i need to wait & let it sort itself out or do i need to boot pc up & go into the settings and change a few things for its connection details?
airpirt ex. has its own wifi network & thats all working but saying no internet connection, vigor 120 has all lights on but no internet light. so im guessing its the internet settings required for the draytek need tweeking?
Message 1 of 7
(16,714 Views)
6 REPLIES 6
16-05-2012 2:13 PM
you'll need to enter your PN login details into the vigor to get the connection working, it needs to authenticate to be able to work.
the one you got from PN would have had this done for you already (possibly via tr-069)
Message 2 of 7
(902 Views)
16-05-2012 2:44 PM
so i boot my vista pc up, go to the internet settings/find the router login and put in the plusnet settings basically?
can plusnet not do this for me if i call them?
Message 3 of 7
(902 Views)
16-05-2012 2:55 PM
Apologies, reading the Vigor manual, you need to put the connection info into your airport extreme
Message 4 of 7
(902 Views)
17-05-2012 8:24 AM
hhhhhmmmmm still having issues, was up till 2 am trying do this with still no luck!
from reading around on internet it may have something to do with 'Bonjour' that you have from apple on a windows pc, will have a dabble at that tonight when i get in.
have also gone through the settings of the airport extreme utility on the ipad & that has not been able to do anything just clarifys that the A.E. is working fine & dandy but no internet. It does however say there is no or isue with DNS?
does that shed some light on the issue?
Message 5 of 7
(902 Views)
17-05-2012 9:11 AM
Quote vigor 120 has all lights on but no internet light. so im guessing its the internet settings required for the draytek need tweeking?
That's right, I've no idea what the Internet light on the Vigor 120 is used for ( and the manual doesn't mention it! ). The 120 is just a modem, you connect its LAN port to the WAN port on the Airport. You then need to configure the Airport Extreme with your PlusNet ISP settings, i.e the username ( in the form username@plusdsl.net ) and password that you use to login to the PlusNet portal.
Message 6 of 7
(902 Views)
26-06-2012 7:46 PM
Hi Guys,
I too have the Vigor 120 and AEBS - I can't get the sodding setup to work either. Did you get it working? if so, what did you do?
Message 7 of 7
(902 Views)
