download speed dropped to 350kbps from 2.7mb - could you please reset this?
- download speed dropped to 350kbps from 2.7mb - cou...
- « Previous
- 1
- 2
- Next »
Re: download speed dropped to 350kbps from 2.7mb - could you please reset this?
07-09-2010 3:08 PM
HI mattdj,
I understand your philosophy about energy saving, I am a great one for it myself. Turning off a router doesn't always cause issues but it sometimes can. I know a router will use very little energy, roughly 0.24kwh per day. So I wonder would it be worth at least leaving it on while we see if it clears the fault. At least that way we can rule that possibility out.
Jojo
Jojo
Message 16 of 22
(477 Views)
07-09-2010 3:10 PM
The best option is to leave the router on permanently (I have mine on a UPS so it doesn't drop even during a power cut!).
Second best is to turn it on during daylight hours and then leave it on until you have definitely finished with it for the day and it will then stay off until the next day.
Third best is similar but turning it on when first needed even if that is late afternoon/evening. This may result in speeds which are a little slower.
Then a long, long, long way behind is to keep turning it on and off several times a day. That is a sure fire way to get [Censored] speeds.
Don't forget that turning equipment on and off shortens it's life due to the repeated heat up/cool downs, so the absolutely minimal amount you save by being 'green' will be more than offset by you having to replace the router earlier.
Message 17 of 22
(477 Views)
07-09-2010 4:28 PM
Hi Jojo,
I have left it on since sunday, any 'connection drops' would have been me rebooting to change firewall settings, I will leave it on until this is sorted, but can I opt out of being rebanded automatically? because It has been honestly painful trying to get anything done through the Ticket system.
I would much rather opt out as It seems very inpractical to be worried about when I can switch off or reboot a router.
No matter how small an amount of energy it would still be a complete waste
Cheers,
Matt
Cheers,
Matt
Message 18 of 22
(477 Views)
07-09-2010 4:48 PM
Hi mattdj,
Thank you for that. I am looking into the possibility of having you opted out too. I will keep you posted.
Jojo
Jojo
Message 19 of 22
(477 Views)
08-09-2010 10:45 AM
HI mattdj,
As per your conversation with Ben we have now been able to lift the banding and you should see the results of this within 24-48 hours.
Jojo
Jojo
Message 20 of 22
(477 Views)
08-09-2010 5:04 PM
Thanks very much for your help Jojo.
Matt
Matt
Message 21 of 22
(477 Views)
08-09-2010 5:09 PM
At your service Matt
Message 22 of 22
(477 Views)
- « Previous
- 1
- 2
- Next »
