double upload
- double upload
double upload
21-12-2009 3:16 PM
Hi i have heard a few people saying they have had their upload doubled
I get 448kbps upload on normal adsl just now could i have this doubled.
How much extra does it cost?
What would i have to ask for to get it done?
Thanks for your help
Baz
Baz
Message 1 of 6
(1,020 Views)
5 REPLIES 5
Re: double upload
21-12-2009 3:23 PM
If you're on standard 'upto 8MB' ADSL then there's an add on called Max Premium, which gives you priority on the BT network, and an increased upload of 832k.
If you're on 'upto 20MB' ADSL2+ then we need to send a request to increase your upload, but this can in some cases have a negative impact on the downstream speed.
Message 2 of 6
(481 Views)
Re: double upload
21-12-2009 3:31 PM
Yeah its standard up to 8MB
Where would i find this add on and how much extra is it?
Cheers
Baz
Cheers
Baz
Message 3 of 6
(481 Views)
Re: double upload
21-12-2009 3:35 PM
It's about £9 per month, you can sign up for it here http://portal.plus.net/wizard/?wizard_id=20
Also gives you elevated performance on the BT bit of the network.
Message 4 of 6
(481 Views)
Re: double upload
21-12-2009 4:24 PM
I was wanting the extra upload to be able to host more people online gaming,
What would be the advantages of elevated performance on the BT side of the network (lower pings)?
Cheers
Baz
Cheers
Baz
Message 5 of 6
(481 Views)
Re: double upload
21-12-2009 4:50 PM
Sorry I forgot to mention the cost. It's £8 per month, and you can add it via the portal.
The priority service on BT's side means you'll see better peak time performance if your exchange is busy, and if you need to raise a speed fault at any point the minimum speed threshold is higher.
Message 6 of 6
(481 Views)
