did a Pipe just drop?
- did a Pipe just drop?
24-01-2009 4:55 PM
Just Lost Connectivity for 10mins or so, had to cold reboot to get connected again
FTTP 500 regrade from Tues 28th November
Message 1 of 3
(808 Views)
2 REPLIES 2
Re: did a Pipe just drop?
24-01-2009 6:26 PM
It was possibly the Gateway you were on.
PTE-AG1 has had a lot of drops this afternoon.I was on that one and I moved to another.
If you have a "connect/disconnect" button on your router's status page you can use that to disconnect your Internet connection (as opposed to broadband connection) so you don't lose sync. Most routers re-connect automatically (if not, press the connect button) and you'll probablybeon a different gateway.
Message 2 of 3
(337 Views)
26-01-2009 12:05 PM
We certainly haven't seen any gateway drops since Monday.
By that I mean that none of them have "gone down".
Message 3 of 3
(337 Views)
