connection speed dropped to 0.5MB
- connection speed dropped to 0.5MB
- « Previous
- 1
- 2
- Next »
Re: connection speed dropped to 0.5MB
18-02-2015 9:59 PM
18-02-2015 10:02 PM
18-02-2015 10:04 PM
At a 6dB margin you're looking at around 9mbps sync, assuming your line is of decent quality, based on your attenuation.
My guess would be either you've got an HR fault somewhere, and DLM has put you on the 288-575 banded profile, or there was some disruption to the line (roadworks, construction, etc) that occurred when you weren't using it, and DLM responded to that.
It's quite possible a ccSNR would sort things out, which PlusNet can do from their 1st/2nd line support (give them a call).
If that doesn't sort it out, it could indeed be an HR fault in which case OR are going to have to come out anyway; might as well wait for that before replacing the master socket yourself.
You said you don't have one already; I assume you mean you've got an old fixed-plate LJ 2/1A; not having a master socket at all doesn't really make sense In which case, you can simulate the NTE5 test socket by removing the LJ 2/1A, pulling the wiring except for 2 and 5, and then plugging directly into it.
18-02-2015 10:06 PM
I doubt it was anything to do with an HR fault mdc, but it is banded.
18-02-2015 10:11 PM
Quote from: thebigyin I have raised a ticket but after 48 hours I still have had no response from the tech team. How long does it take them to respond?
How did you raise the fault ticket - phone call or direct through the support centre on the portal or via http://faults.plus.net ?
Posting the ticket number on here will greatly assist the CRT to get on the case.
18-02-2015 10:13 PM
Fault haven't got back to me yet and its been over 48 hours thats why I am on here and I haven't been doing lots of disconnects
mdc
i usually only had speeds of about 5-6Mbps but having 0.5Mbps just sux and yes I have the old fixed plate I am just going to change it so I have the NTE5
18-02-2015 10:17 PM
it was through the http://faults.plus.net - #99437595
18-02-2015 10:21 PM
18-02-2015 10:25 PM
- « Previous
- 1
- 2
- Next »
