connection problem
- Re: connection problem
connection problem
30-09-2013 9:06 PM
Hi ,
I have just had a 4/5 disconnects in the space of about 10 mins after having a stable line for a few days i thought all was good could someone check this for me thank you .
Message 1 of 2
(474 Views)
1 REPLY 1
01-10-2013 8:50 AM
I've checked over your line and can see the bout of disconnections you had last night;
<img src="http://community.plus.net/visualradius/generated/image13806135232467.png"/>
Everything seems to be ok now. I'd suggest monitoring your connection and if it was to happen again then run through our faults troubleshooter.
Message 2 of 2
(250 Views)
