connecting nintendo via wireless router
- Re: connecting nintendo via wireless router
- « Previous
- Next »
17-03-2010 3:45 PM
21-03-2010 6:54 PM
My only conclusion is that it is the router that is a problem. Can anyone recommend another wireless router that will not give me the same problems?
10-05-2010 11:55 PM
11-05-2010 8:06 AM
As to what else I have hooked up - my pc is very happy as is my daughter's DSi.
good luck!
11-05-2010 4:52 PM
All The Best,
Steve
11-05-2010 6:52 PM
Thanks to everyone for the advice and support - still not working on the wireless, so must be a problem for Thomson then!
15-05-2010 11:36 AM
15-05-2010 11:43 AM
Quote it says 'the access points security settings are not supported by the nintendo ds'
The DS Lite only supports WEP encryption, the DSi will support WPA. Your Thomson router by default is set to use WPA because its much more secure than WEP. If you are happy with the limited security provided by WEP encryption then you can change the router configuration to use WEP and then your DS Lite will connect to it.
15-05-2010 11:57 AM
- « Previous
- Next »
