community help investigating my line...
- community help investigating my line...
- « Previous
- 1
- 2
- Next »
Re: community help investigating my line...
04-12-2009 10:06 AM
Ah OK. It's just that looking at the times along the bottom I couldn't believe you were turning the computer off for such incredibly short periods!
BTW are you running the latest version of RouterStats? There's been a number of improvements recently.
Message 16 of 21
(293 Views)
04-12-2009 10:13 AM
think so as i only installed last week 5.7f?
Message 17 of 21
(293 Views)
04-12-2009 10:19 AM
That's fine. It's just that he has tried to add indicators to show when there are breaks in the monitoring.
Could you indulge me and explain why you powered the PC off in the gap between 21:49:43 and 21:53:43. It's just that that also seems to coincide with a change in sync speed and noise margin (although a smaller change).
Message 18 of 21
(293 Views)
04-12-2009 11:03 AM
no idea ... the problem is the big change
Message 19 of 21
(293 Views)
04-12-2009 11:59 AM
I beg to differ: any lost sync and change of sync speed and noise margin is indicative of an unstable line and hence the BT systems will (correctly) up the target etc. to try to achieve stabilisation.
Message 20 of 21
(293 Views)
04-12-2009 12:46 PM
but as i've said there has been no loss of sync, apart from the 1 that the dlm did when it placed me back on banding
so as i've said the graphs show no errors
Message 21 of 21
(293 Views)
- « Previous
- 1
- 2
- Next »
