cant change wan mtu on technicolor router
- Re: cant change wan mtu on technicolor router
29-05-2014 1:20 PM
when i telnet into router and try to change wan mtu i get error.says changes wont be saved on dynamic ip.i can change local but not wan
Message 1 of 5
(3,604 Views)
4 REPLIES 4
29-05-2014 1:30 PM
Have you checked with:
ip iflist
The MTU may have changed despite the error.
ip iflist
Message 2 of 5
(2,969 Views)
29-05-2014 4:07 PM
yea i checked after m8 still didnt work.
Message 3 of 5
(2,969 Views)
29-05-2014 5:20 PM
The following works for me, get the error but the mtu still changes.
ip ifconfig intf=Internet mtu=????
saveall
Alternatively you could try:
ppp ifdetach intf=Internet
ppp ifconfig intf=Internet mru=????
ppp ifattach intf=Internet
saveall
If you use this second one, I would make sure the setting is the same in the ip section.
saveall
saveall
Message 4 of 5
(2,969 Views)
29-05-2014 6:25 PM
the top 1 worked thanks for your help m8
Message 5 of 5
(2,969 Views)
