cant access the router
- Re: cant access the router
16-05-2015 12:01 AM
Hi, I can't access the router even though I have reset it, anyone got any suggestions please?
Message 1 of 9
(1,914 Views)
8 REPLIES 8
16-05-2015 1:02 AM
What router are you using?
Message 2 of 9
(1,275 Views)
16-05-2015 2:14 AM
Technocolour on tg5829. I wonder what it could be ? Thank you for your reply.
Message 3 of 9
(1,275 Views)
16-05-2015 9:52 AM
What error are you seeing when you try to access it?
Message 4 of 9
(1,275 Views)
16-05-2015 10:27 AM
I'm not seeing error , I'm unable to sign in , I managed to sign in once and clicked on a device to remove it from the router (my old iPhone because I've purchased another one!) And I was unable to remove the old iPhone and I was signed out! And not no matter what I do I can't sign in , nothing happens ? Thank you for your reply .
Adie:quote
Message 5 of 9
(1,275 Views)
16-05-2015 10:47 AM
Um, were you using your old iPhone to delete the device (itself)? Are you using the default TG582n password or did you change it to a different one?
edit: spelling typo.
Message 6 of 9
(1,275 Views)
16-05-2015 11:04 AM
hi no I was using this one HTC , I have sold the old one. I have tried everything you can think of. Thanks
Quote Um, were you using your old iPhone to delete the device (itself)? Are you using the default TG582n password are did you change it to a different one?
[Moderator's note by Adie (dvorak): Full quote of preceding post removed, as per Forum Rule]
dick:green Quote fixed.
Message 7 of 9
(1,275 Views)
16-05-2015 11:05 AM
As a last resort you could factory reset the router, but this will remove any settings you've added to it.
Message 8 of 9
(1,275 Views)
16-05-2015 10:00 PM
thank you for your reply , I have managed to fix it now thank you.
[Moderator's note by Dick (Strat): Full quotes of preceding post removed, as per Forum Rule]
Message 9 of 9
(1,275 Views)
