can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
- Re: can my connection go any faster or is this as...
10-06-2011 3:29 PM
Download Speed
2232 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2232 Kbps
Additional Information:
Your DSL Connection Rate :4608 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
if thats of any help and my line status from the router has this info
Broadband Line Status
Refresh
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:03:06:33
Line Coding Trellis Off Line Up Count 1
Statistics Downstream Upstream
Line Rate 4608 Kbps 448 Kbps
Noise Margin 9.5 dB 22.0 dB
Line Attenuation 51.0 dB 30.0 dB
Output Power 19.6 dBm 11.9 dBm
if thats of use as you can see line up time is only 3 hours as it drops every day at least once
Re: can my connection go any faster or is this as good as it gets
10-06-2011 3:32 PM
RefreshReset
Latency Type Interleave Line Up Time 00:03:13:02
K (number of bytes in DMT frame) 145 15
R (number of check bytes in RS code word) 12 16
S (RS code word size in DMT frame) 1 8
D (interleaver depth) 16 2
Super Frames 681273 681271
Super Frame Errors 54 0
RS Words 46326582 5790803
RS Correctable Errors 3403 0
RS Uncorrectable Errors 476 0
HEC Errors 51 0
OCD Errors 3 0
LCD Errors 0 0
ES Errors 0 0
10-06-2011 3:49 PM
However to get any more effective speed you would need to have the speed increased to 5120kbps minimum (IP profile increased from 4000kbps to 4500kbps) but to be honest that may not be possible.
I have the same attenuation as you and I can't get anything over 5000kbps with a 6dB noise margin.
However your present IP profile is 3500kbps which tends to indicate that a resync over night is dropping your speed to below 4544kbps (4000kbps IP profile) so you need to find out what is causing the drop and fixing it.
The first thing to try is connecting the router to the test socket and see if things improve
For comparison these are my stats
Noise Margin: 5.6 dB
Connection Rate: 4800 Kbps
Line Attenuation: 51.0 dB
10-06-2011 6:03 PM
The connection dropping is a major annoyance i just dont know what to do to stop it, we moved router as it was on an extension cable to right by the master socket so plugged straight in via filter one phone and sky also plugged in unless i do need a new router as has been suggested to replace my BT Voyager 2110 as my connection drops daily.
How long do i need to be plugged into the test socket as i guess my home phone wont work then
Re: can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
10-06-2011 6:15 PM
So just as a suggestion, try running for a while without the Sky box connected to the phone line, and see whether the broadband drops reduce or disappear ?
10-06-2011 6:23 PM
10-06-2011 6:25 PM
10-06-2011 6:35 PM
10-06-2011 6:38 PM
10-06-2011 7:07 PM
If you go down that route you need to leave it connected long enough to see if that fixes the problem
10-06-2011 7:21 PM
10-06-2011 7:41 PM
You need to fit the filter to the test socket and the router and phone to the filter
10-06-2011 7:51 PM
10-06-2011 8:05 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
3105 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 3105 Kbps
Your DSL Connection Rate :4704 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
and this
RefreshReset
Latency Type Interleave Line Up Time 00:00:36:09
Line Coding Trellis Off Line Up Count 3
Line Rate 4704 Kbps 448 Kbps
Noise Margin 9.4 dB 22.0 dB
K (number of bytes in DMT frame) 148 15
Super Frames 127562 127560
Super Frame Errors 7 0
RS Words 8674222 1084260
RS Correctable Errors 338 0
RS Uncorrectable Errors 71 0
HEC Errors 7 0
OCD Errors 1 0
LCD Errors 0 0
ES Errors 0 0
shame i dont understand most of it
10-06-2011 8:12 PM
Quote Line Rate 4704 Kbps 448 Kbps
The point is that your speed test result is limited by the IP profile.
This is effectively set by your sync speed with preset bands as given here http://www.kitz.co.uk/adsl/IPprofile.htm#IP_and_bRAS_profiles
If your line holds sync at 4704kbps the IP profile will increase to 4000kbps in a couple of days
