can i use a home hub 3 on plusnet
- Re: can i use a home hub 3 on plusnet
12-09-2014 1:50 AM
i have a home hub 3 lying about is it possible to configure it to use on pn broadband cheers tony
Message 1 of 3
(759 Views)
2 REPLIES 2
12-09-2014 2:53 AM
I'm using a Home Hub 5 and it works great. As far as I know you can use a HH3 on PlusNet. There's a thread on here which explains how to set it up, try a search for Home Hub and you should find it.
Message 2 of 3
(453 Views)
12-09-2014 2:59 PM
The guide is here
Message 3 of 3
(453 Views)
