can any one help with this
Re: can any one help with this
DSL Connection
Link Information
Uptime: 5 days, 23:35:32
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 9.0 / 15.0
SN Margin (Up/Down) [dB]: 23.0 / 11.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 684
HEC Errors (Up/Down): 0 / 589
Legend
Fixes: 168
I can't see any immediate problem with your account or your line, however I can see you've not rebooted your router since we received the latest profile update. Can you try this (preferably in daylight hours) and try another speedtest please.
What errors are you getting now when trying a BT Speedtest?
first thing
thank you  for the help
the errors before  appear to be fixed  ive  got the  bt test below
i know i can get 6 megs i had this on friday
i will reboot  the  router  and  see if this helps now
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
1848 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1848 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
dick:quote
Legend
Fixes: 168
Hmm that's odd as both of the systems we check in show it as 7150, sounds like somethings amiss. Leave it with me and I'll see what we can do.
Legend
Fixes: 168
Doesn't look like the first idea has helped, can you go through the checks at http://faults.plus.net and raise a speed fault? Post in here when you've completed the checker and I'll push the fault through.
i still have a few days before my 10 day training period are up  should i wait
or report the fault now ?
dick:quote
