bt speedtester ip profile ?
- bt speedtester ip profile ?
06-01-2008 10:25 AM
i joined the elite on friday and straight away my throughput has been a stable 1.8 meg up from my previous provider Poopex which was averaging only .5 of a meg
these are my results -
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5952 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1864 kbps
what im wondering about is the profile, is or will it change as my line supports up to 8 meg and 6.5 to 7 meg throughput ?
any help welcomed
Re: bt speedtester ip profile ?
06-01-2008 10:54 AM
If you were on max with Pipex it should uplift a bit quicker than that, next couple of days or so.
Hope that helps, please let us know.
06-01-2008 11:20 AM
i was on the 8 meg max - not that i ever got any where near that lol
ill keep an eye on it then over the next few days thanks again
07-01-2008 11:59 AM
If you have a read of the speed faults troubleshooting guide in my signature, hopefully it should explain the situation to you a little better.
I'd be inclined to think that you were never on the full 8Mbps service with PIPEX, but just the marketed "upto 8Mbps" version.
09-01-2008 7:52 AM
DSL connection rate: 448 kbps(UP-STREAM) 5600 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1871 kbps
as of this morning
09-01-2008 9:25 AM
One thing which may help, which I'm not sure if you have been doing, is to reboot your router on a daily basis in the early days of your new connection.
This can help BT to identify that a change in IP Profile is required.
09-01-2008 9:36 AM
10-01-2008 4:12 PM
DSL connection rate: 448 kbps(UP-STREAM) 6368 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1872 kbps
Why is the profile refusing to budge up come on bt take note
10-01-2008 4:16 PM
Could you possibly raise a fault via http://faults.plus.net so that we can get this raised to BT please?
You may initially get a "none found" response, but don't worry about that. we should be able to get BT to recalculate your profile for you.
10-01-2008 4:28 PM
10-01-2008 4:44 PM
can you confirm that the profile will be looked at
10-01-2008 4:46 PM
I'll go and raise it to BT now for you.
10-01-2008 4:48 PM
11-01-2008 8:56 AM
DSL connection rate: 448 kbps(UP-STREAM) 6624 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1863 kbps
11-01-2008 10:01 AM
I replied to your ticket earlier this morning.
Your fault is now back with BT. I'm just waiting on them to recalculate your IP Profile.
