bt speedboost is it possible?
- bt speedboost is it possible?
28-04-2011 9:31 AM
podman
Re: bt speedboost is it possible?
28-04-2011 10:49 AM
That's a new one on me. As for getting 11Mb to the cabinet I think that's irrelevant as your speed is determined from the exchange, not the cabinet.
Jojo
28-04-2011 10:52 AM
I think the guy is referring to a "Broadband Boost" engineer. Those guys specialise in internal wiring and such like designed to improve speeds, but it's not a miracle fix.
He's suggesting that you're seeing a 6Mbps drop ion speed from the cabinet to your router - could be a fair stretch of cable from the cab to yours?
28-04-2011 10:57 AM
he said the test from the exchange to the cabinet showed the line at 11mb. it is less than 1/4 mile between house and cabinet, a couple of mins walk.
podman
28-04-2011 11:33 AM
The BT system we test on is down at the moment and I wanted to check a couple of things. I'm sure it'll be back up soon so I'll give you an update later.
Jojo
28-04-2011 12:12 PM
thanks for all your help. In have to say PN are the most helpful company I deal with.
podman
[added] 0.2 of a mile to cabinet, though i realise it might not make the most direct route
29-04-2011 11:43 AM
is the system back up that you mentioned you could use to do a few tests?
regards,
podman
29-04-2011 12:10 PM
Having checked the line you're getting more or less the right speed for your line stats. I'll ask about and see what I can find out about whether the speed should depreciate that much from the cab. I do, however, suspect that it either doesn't run in a straight line or is slightly deteriorated over time.
Jojo
29-04-2011 12:13 PM
Box is right at front of estate and it runs up the road to house. Both e and d side recently replaced.
podman
29-04-2011 12:28 PM
Just been checking around some more and your speed is above the fault threshold rate and also falls within expected rates from the BT availability checker so we wouldn't be able to raise it as it will just get sent back to us as falling within expected limits.
Jojo
29-04-2011 12:33 PM
one can always dream. Wish he hadn't said anything though to think it's got the potential for another 5 mb until it gets to the cabinet 😞
guess i'll need to waith for fttc or fttp at somepoint, though checking the published webpages Scotland will get little cover in the near future.
30-04-2011 12:38 AM
30-04-2011 10:12 AM
