bsmith1 Slow Upload speeds (Fibre)
- Re: bsmith1 Slow Upload speeds (Fibre)
10-06-2013 12:43 PM
I am also suffering from low upload speeds, used to get over 13Mbps now getting 0.8Mbps
Got BT engineer out to test - No Fault found
But still slow upload.
Message 1 of 5
(830 Views)
4 REPLIES 4
10-06-2013 12:59 PM
Post split off as it is a totally different problem
Message 2 of 5
(506 Views)
10-06-2013 2:08 PM
Our faults team will take a look through the engineer notes, it would be good to know if the engineer has stated that your upload speeds are syncing higher than the .8Mb/s you've reported. From what I can see they are.
Are you currently connected direct to the modem, so no router in use?
Message 3 of 5
(506 Views)
10-06-2013 2:16 PM
Quote from: bsmith1 I am also suffering from low upload speeds, used to get over 13Mbps now getting 0.8Mbps
I wish you luck and hope your fault progresses better than mine.
My upstream speed is 0.6mbps on Plusnet fibre.
After 5 BT visits over a few months they have failed to find any fault and just blame everything except their own lines / equipment.
Rather suspect I will have to move ISP to Andrew and Arnold to get any action on this.
Message 4 of 5
(506 Views)
10-06-2013 3:08 PM
@npr
Sorry this hasn't been resolved yet. Let me know how you go on with the engineer visit on Wednesday. It's definitely booked in for you.
Message 5 of 5
(506 Views)
