broadband start date
- broadband start date
27-06-2011 3:01 PM
My phone line was installed a week ago and Phone works no problem, but my wifi router is still showing as not ordered and I am supposed to be having my braodband up and active on Wednesday!
How long till I get router and active broadband?
Any suggestions would be great!
Many thanks
Many thanks
Message 1 of 9
(1,053 Views)
8 REPLIES 8
Re: broadband start date
27-06-2011 3:32 PM
Message 2 of 9
(672 Views)
27-06-2011 3:37 PM
Message 3 of 9
(672 Views)
28-06-2011 7:49 AM
BrilliAnt thanks!!
Message 4 of 9
(672 Views)
29-06-2011 12:12 PM
I have just checked my account and it now says there seems to be a problem with my line!! I am due to be connected to braodband today, so can you tell me if this is going to happen.
It has been a bit of a wait to get connected so i really dont want any more delays.
Mant thanks
Mant thanks
Message 5 of 9
(672 Views)
29-06-2011 12:19 PM
hello this also happened to me, I had to raise a support question when I had been waiting 3 weeks and nothing had happened. they then turned round and said that there had been an unknown error. They then reseubmitted the order and it came on 6 days later.
Message 6 of 9
(672 Views)
29-06-2011 12:22 PM
Oh No!! The kids are desperate to get back on X box live!! Hope this really is just a blip!!
Fingers crossed!!
Message 7 of 9
(672 Views)
29-06-2011 12:33 PM
just a tip.
If there is ever a problem with any order you place with plus net.
Plus net are not automatically notified of the error, generally I have found it is up to you to give them a buzz and let them know.
If your order status page does not give the text "Your broadband is expected to be active on "Insert Date" please note the date may change"
It is likely that the error is that the order was rejected and will need manual submission by one of the Plus net team.
Also if you have an android phone you could download an app that will let you tether it to the xbox?
Message 8 of 9
(672 Views)
29-06-2011 3:48 PM
HI sofistikate1974,
It looks as thought it's gone active this afternoon, so you should be ok to connect now.
Jojo
Jojo
Message 9 of 9
(672 Views)
