broadband speed
- broadband speed
Re: broadband speed
10-01-2013 3:52 PM
Considering the manner of your post #86, if I were Fireant, and without my knowledge, I would have taken that to mean oh they won't investigate so I'm off. It has not been proven AFAIK that a fault needs to be raised to BTw. If Plusnet don't even want to investigate further, then they will lose a customer.
Re: broadband speed
10-01-2013 4:00 PM
If they had been a problem withtitanadsl then i would of got straight onto them as i think really you know roughly what speed your line can handle but ive never seen any more than 12mb from joing in october but i would have really thort it would have been the same and reason why i joined is it was cheaper and thort id give them a go s speeds should be the same and would have been happy with same as i get usual and would have stayed as end of the day i dont like keep moving around more hassel than its worth to be honest .
Re: broadband speed
10-01-2013 4:08 PM
Re: broadband speed
10-01-2013 4:10 PM
Quote from: Fireant i know for sure the speeds were great wireless as between 15mb and 16mb but dont know the speeds threw ethernet as i use wireless all the time .
Re: broadband speed
10-01-2013 4:11 PM
Wired http://community.plus.net/forum/index.php/topic,110253.msg947737.html#msg947737
Re: broadband speed
10-01-2013 4:14 PM
And with regard to yet another argument breaking out, seriously, stop it. Once again, it does not do anyone any favours. There are no points to be won.
As far as I can see, aside from the finger pointing pretty much all the information that's been put in so far is relevant to the issue - can I suggest that those who feel the need to take umbrage when other people post information stop before they reply, take a breath and think 'is this aimed at me or is it trying to help the OP, which is after all the point of these forums?' and apply it to their own reply before posting?
Thank you.
Re: broadband speed
10-01-2013 4:19 PM
Re: broadband speed
10-01-2013 4:21 PM
Re: broadband speed
10-01-2013 4:24 PM
Your router is actually syncing at a higher speed than you are seeing, you should be seeing 18MB/s so it may be a case that the speeds are being lost though your wireless connection.
Re: broadband speed
10-01-2013 4:36 PM
Re: broadband speed
10-01-2013 4:38 PM
Re: broadband speed
10-01-2013 4:41 PM
Edit: Just seen your post. Could you try the tester I linked on both PC's using wired links please?
Re: broadband speed
10-01-2013 4:48 PM
Provided these drops are you resetting the router, that is:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13578365046325.png"/>
Re: broadband speed
10-01-2013 4:52 PM
Re: broadband speed
10-01-2013 9:49 PM
