broadband speed
- broadband speed
Re: broadband speed
09-01-2013 11:56 PM
Re: broadband speed
09-01-2013 11:58 PM
Edit: Hopefully someone will pick this up again in the morning.
Re: broadband speed
10-01-2013 11:03 AM
Re: broadband speed
10-01-2013 2:30 PM
Re: broadband speed
10-01-2013 2:38 PM
Re: broadband speed
10-01-2013 2:52 PM
Re: broadband speed
10-01-2013 3:02 PM
Re: broadband speed
10-01-2013 3:07 PM
Re: broadband speed
10-01-2013 3:11 PM
Re: broadband speed
10-01-2013 3:13 PM
Just checked your account and it's showing we've received a PSTN cease notification? Basically that means we've been told that you're moving your phone line and service away from us to an LLU provider.
If that's not the case you'd need to raise a ticket and ask us to stop the cease, however if it is we won't be able to raise a fault for you I'm afraid as the LLU Cease order on the line prevents us from doing so.
If you could let us know what's happening there that'd be great, thanks very much.
Re: broadband speed
10-01-2013 3:15 PM
Re: broadband speed
10-01-2013 3:17 PM
Re: broadband speed
10-01-2013 3:19 PM
Re: broadband speed
10-01-2013 3:25 PM
It does matter when it's for, because if it's before his expected transfer date then somebody isn't following the rules., so really your interjection is inappropriate, Plusnet may well be about to lose a customer and I'm sure would want to do all they could to prevent that.
Re: broadband speed
10-01-2013 3:42 PM
Plusnet pointed out that they would be unable to raise a fault with BTw if they thought that was needed and to check that he wanted the cease to go ahead (usually when people leave it's to give up fault investigation with the current provider and see if someone else can do better).
You asked about the date.
I posted to point out that irrespective the date BTw would not accept a fault - Fireant needs to be aware of that because it could limit the investigations Plusnet can perform.
