broadband speed
- broadband speed
broadband speed
06-10-2007 1:23 AM
Also is this the best speed I can ever expect to get no matter what package I am on ?
Re: broadband speed
06-10-2007 1:37 AM
Try doing a BT speedtest - www.speedtester.bt.com - and see what your IP profile is as that determines your data rate.
Re: broadband speed
07-10-2007 4:07 PM
Sorry to post such a simple query but I am new at this game.
Re: broadband speed
07-10-2007 4:12 PM
Re: broadband speed
08-10-2007 9:14 AM
On October 6th, your rotuer resynchronised with the exchange on October 6th at 576Kbps. your profile was subsequently dropped to 500Kbps by BT. On the 8th (today) BT took your highest stable synchronisation speed of 864Kbps and subsequently applied a profile of 750Kbps. I'll make some changes at this end to slightly improve your throughput, but you'll need to restart your modem or router for them to tke affect.
Re: broadband speed
08-10-2007 11:15 AM
BT test Down 2912
Up 448
Think bb.
IP profile 2500
DSL connection rate up 448 Down 2912
Actual IP in test 1369.
On PN connections, 2500
since 17/09 my speed as been 1300 appox.
Is that the top speed I can expect and what is this about BT adjusting it after several days.
I would appeciate any of you guys opinions.
Re: broadband speed
08-10-2007 11:20 AM
I Managed to access the BT test results as follows,
IP Profile 750 kbps
upstream 448 kbps
Downstream 1088 kbps
Actual IP Throughput 686 kbps.
One other point, I switch off my modem each time I come off the computer. could this have any affect on my speeds ?
Re: broadband speed
08-10-2007 11:49 AM
It's possible that each time you restart your router, you may see a different synchronisation speed. Your profile is calculated on those speeds.
I'd definitely recommend playing around with your filters and connecting into the master socket just to see if you notice an improvement to that speed.
Re: broadband speed
08-10-2007 11:57 AM
Looking at the ticket you've raised, it looks like you haven't tried rebooting your equipment in a very long time. Could you try doing this for me please?
I'm not sure why you would be seeing those lower speeds, but hopefully a reboot will help.
Re: broadband speed
08-10-2007 8:26 PM
Re: broadband speed
08-10-2007 10:26 PM
BT Test.
IP profile 2500kbps
DSL connection rate UP 448kbps
Down 2656 kbps
Actual IP in test 1771kbps at 1000hrs
Think BB Test.
Date 08/10/07 22:10:26
Speed Down 2060.56 Kbps ( 2 Mbps )
Speed Up 378.12 Kbps ( 0.4 Mbps )
Port 8095
Server speedtest1.adslguide.org.uk
IP Address 87.114.147.16
Do you think these are now OK or should I try booting again at a later date.
Re: broadband speed
09-10-2007 10:39 AM
For an IP Profile of 2500, you're getting results pretty similar to what I would expect you to.
I reckon all should now be well.
Re: broadband speed
09-10-2007 8:25 PM
