broadband speed
Teds31
broadband speed
I have had really low speeds and drop outs since xmas ,I had an engineer out and he said he had cured the problem. Now its gone wrong again and I cant get any response from PN on my question 141348633, I'm getting a bit fed up with PN,maybe time for a change.
9 REPLIES 9
Fixes: 290
Re: broadband speed
I can see we've picked the fault up today.
Apologies for the delay.
 Matthew Wheeler
Teds31
Re: broadband speed
After the problems I had before (see above) I have had 2 visits from engineers to ne avail my speed and disconnection is appalling ,it seems a waste of time,I now cannot use my on line banking and playing any type of game is impossible. Please dont fob me off with another engineers visit as that is also a waste of time ,for goodness sake get me reliable connection. Ted
Fixes: 759
Re: broadband speed
I am sorry to hear you are still having problems with your broadband service. I'm testing your line and I'm not identifying an issue, your connection has been stable for the past 13 days with only 1 drop at a speed of around 6.5 Mb/s.
Please could you run the BT speedtest for me by going to www.speedtest.btwholesale.com using a wired connection from a PC or Laptop, completing the further diagnostics and let us know once you've done this?
I apologise for the inconvenience caused.
Teds31
Re: broadband speed
I am beginning to think I am wasting my time and yours. The internet earlier today was impossible to use, but if you say there is no fault then forget it,is the easy way.Ted
Fixes: 759
Re: broadband speed
I'm sorry to hear this Ted.
I'm here to help, but we'll need to troubleshoot to get to the source of the problem you're experiencing.
Let us know if you need any further assistance.
Fixes: 43
Re: broadband speed
@Teds31 how are you connecting, wired or WiFi? And which device are you using?
Teds31
Re: broadband speed
I have WiFi with A" THOMSON ROUTER ".
Gel
Seasoned Pro
Fixes: 17
Re: broadband speed
Fixes: 32
Re: broadband speed
A view of the router stats would be a useful starting point.
