broadband speed has collapsed
outinthesticks
over the last few days my broadband speed - wired and wireless - seems to have nosedived, this morning the BT speed checker is showing zero readings for both download and upload. Have tried all the usual things to no avail. I strongly suspect it is due to lots of people working and studying from home, as later last night the speed returned to its usual 2.5-2.8Mbps (yes I know, 6 miles from the exchange). . I'd be grateful if Plusnet would check the line (sorry don't have time to sit in a telephone queue).
13 REPLIES 13
Legend
Fixes: 254
Re: broadband speed has collapsed
@outinthesticks   Plusnet staff support, like the phone service, is still severely restricted. If you would like help from the community, a good starting point is to have a look at This post and supply as much detail from it as possible.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise. If there is, report a phone fault first, as without a clear phone connection, your broadband will not perform correctly.
If you reply to this topic with as much detail as possible, there are plenty of experienced members who can advise on possible remedies.
If you decide to also post on the Twitter/Facebook accounts and get a response from there, please come back here and say so.
Fixes: 418
@outinthesticks
I assume that you are on ADSL and not fibre?
Are you speed testing with nothing else connected to the internet?
If one of the users is trying to upload, like taking part in a Zoom session, then this will hog all of your bandwidth (and then some) and kill the service to everyone else.
It's not only your terrible download speed that you have to worry about but also the upload speed, which I imagine is in the 100s of KMbps. If you are uploading something intensive whilst trying to download the download 'handshakes' can't get through without massive delays. This is especially true if you have a Plusnet Hub Zero, which suffers from 'buffer bloat'.
It might be worth you moving to another ISP such as BT who have signed up to meeting the Universal Service Obligation, see https://www.bt.com/broadband/USO
outinthesticks
Thanks - yes ADSL, & speed testing with nothing else connected. I don't see how changing ISP will help as no alternatives to ADSL available in my area currently. I also tried the quiet line test, as recommended by jab1 and that is fine.
Legend
Fixes: 254
@outinthesticks Have you checked the post linked to in my reply above? Sight of your router stats might give us a clue.
outinthesticks
0
Legend
Fixes: 254
@outinthesticks I'd edit out identifiable information in that shot. Which router is it please, because it isn't giving all the relevant information.
outinthesticks
thanks - its a fairly new BT Smart Hub (& thanks will try to edit the screenshot)
Fixes: 418
@outinthesticks
Interesting.
The system has only been up for 1 hour 25 minutes. Is there a reason for this, did the line drip earlier or had you switched it off?
Even more interesting is that the network had only been up for 6 minutes. I am assuming that this indicates that the line had been synchronised to the exchange but there was no data connection with the Plusnet  servers.
It’s probably time to report a fault at faults.plus.net.
Legend
Fixes: 254
OK - should have read the post properly and then I would have known.Embarrassed
Somewhere deeper in there is a screen which will give similar information to the picture below - which is more important.
outinthesticks
thanks - when I try to access the router now I get thisScreenshot 2021-01-12 at 12.11.12.png
Legend
Fixes: 254
Any improvement, @outinthesticks ?
outinthesticks
Hi John in the end I rang the help line and a really helpful person established that it was a router authentication problem, now resolved, though the speed is still painfully slow. Thanks for your help and suggestions.
Legend
Fixes: 254
OK. It may take a while to reach your dizzy heights of about 3.0Mbps, but report back if you still have problems.
