broadband from phone extension socket
FIXED- Subscribe to RSS Feed
- Re: broadband from phone extension socket
26-11-2020 10:02 AM
Ok doesn't work so how do I get internet downstairs when MS is upstairs?
Can the extension be manipulated/rewired to provide access?
MS is needed upstairs just with lockdown etc working from home is now a thing.
wifi is bad so need to switch from up to down to up....
Setup at mo is :-
up=MK3 faceplate,openreach modem,own router.
dw=MK3 faceplate,openreach modem,long lan cable,plusnet router
Fixed! Go to the fix.
26-11-2020 11:38 AM - edited 26-11-2020 11:39 AM
If I understand correctly, try:-
MK3 faceplate (MS),openreach modem,own router,long lan cable,(plusnet router)
If you only need one connection remove the plusnet router otherwise just use the LAN sockets or use a 5/8-way switch.
26-11-2020 1:12 PM
Want to do away with the trip hazzard.
I tried cable from own router to plusnet one and the plusnet one wouldn't give/get internet.
Ideally I would want to make the extension internetable if possible.
26-11-2020 4:49 PM
You should leave your modem and router connected to the Mater socket. For some options on how to get internet data downstairs see. https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Distributing-Data-around-Larger-Proper...
29-11-2020 2:10 PM
I thought plugging a LAN cable from my router to the plusnet router would work but doesn't seem to?
29-11-2020 2:26 PM
It will work. Assuming it is 'your' reouter that is connected to the modem and you want to use the Hub One as an access point the settings are here https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/m-p/1385...
Presumably you have an Ethernet cable between the two. You connect the cable to a LAN socket at each end.
30-11-2020 12:11 PM
Hi @teamagoo
Re-reading your original posts I get the impression that you may have tried connecting both routers to the line - one upstairs and one downstairs? This will not work. Try disconnecting the downstairs router from the MK3 faceplate and just use the router as a 4 port switch.
To get rid of the trip hazard of the cable follow one of the routes discussed in @Baldrick1 well laid out help post.
M
01-12-2020 5:31 PM
@Baldrick1 post did the trick,I just hadn't turned off DHCP.
Still got the trip hazard but have internet up and down now.
Thanks guys
