broadband down again
- Re: broadband down again
14-05-2013 3:37 PM
Hello
Any other members having this problem - had it a while back but it has returned - internet is out for ten minutes or longer on random occasions - I even now sometimes get an official BT message saying their server is off line..
Last time it happened was about ten minutes ago for ten minutes.........
Quick update - just happened again - offline for a few minutes with fixed green light on the router
Message 1 of 5
(1,691 Views)
4 REPLIES 4
14-05-2013 4:06 PM
The info in this post should help you fix that: http://community.plus.net/forum/index.php/topic,104933.0.html/
Let us know how you get on.
Adam
Adam
Message 2 of 5
(548 Views)
14-05-2013 4:55 PM
Thanks for trying to help - all I get from trying to enter the DNS servers 212.159.6.9 and 212.159.6.10
is the problem loading page message - a while back Plusnet found I had drop outs all over the place
and even showed me the graph -
Message 3 of 5
(548 Views)
14-05-2013 5:00 PM
No problem at all smokeyone,
Your connection has dropped a few times over the last 24 hours but not to a significant level:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13685471158017.png"/>
the BT landing page you mentioned is usually caused by DNS issues, you may want to try assigning Google's DNS servers which are 8.8.8.8 and 8.8.4.4
Message 4 of 5
(548 Views)
15-05-2013 10:36 AM
Thanks for the help again - will see how it goes -
Message 5 of 5
(548 Views)
