boardband BANDing problem
- Re: boardband BANDing problem
12-04-2012 3:18 PM
Dear Joanne, would you please lift the banding for my broadband connect? the plusnet account page said it should be 5-8M. But now it is still 1M after the engineer changed the socket on the wall.
Message 1 of 6
(1,232 Views)
5 REPLIES 5
12-04-2012 3:35 PM
the socket has been changed. the broadband still goes off every 10 minutes. I am bearing with the painful connection now
Message 2 of 6
(589 Views)
12-04-2012 3:42 PM
Hi rpwd,
I've just changed the profile on our side to 9200 to allow for your new BT IP profile. You should see the increase shortly.
Jojo
Jojo
Message 3 of 6
(589 Views)
12-04-2012 3:51 PM
thank you so much, Joanne, Is there any thing I should do? Should I restart the router as well?
I will be back if the speed gets back to normal.
Message 4 of 6
(589 Views)
12-04-2012 4:17 PM
Nothing you need to do. Once it takes effect it will just drop the PPP session automatically
Message 5 of 6
(589 Views)
13-04-2012 9:28 AM
Thanks for your PM, glad to hear it's ok now
Message 6 of 6
(589 Views)
