:( bad gaming
- :( bad gaming
Re: :( bad gaming
01-10-2012 3:01 PM
Re: :( bad gaming
01-10-2012 3:18 PM
Re: :( bad gaming
01-10-2012 3:28 PM
edit: now its attached
Re: :( bad gaming
01-10-2012 3:42 PM
It's auto-detection is showing it thinks it is the last filetype in the line when you use the open dialogue, which confirms it has used all import filters and failed.
Sorry, but do you still have the capture open such that you can save it again in pcap format?
Re: :( bad gaming
01-10-2012 3:55 PM
Unrelated issue with Opera, its not completing the upload of attachments via the ticket system, its Action buffer gif stays active even though it has completed the upload, same issue with attachments on this forum
Re: :( bad gaming
01-10-2012 4:53 PM
I don't like Opera myself. I'll get Dave T to test this, as I frequently poke him for his love affair with this browser.
I will try and scan over the capture now.
Re: :( bad gaming
02-10-2012 9:17 PM
Ping is starting to spike again, normally 5ms
ptn-ag03,
Re: :( bad gaming
02-10-2012 9:40 PM
This is located in Telehouse North.
Im currently connected to this also ( Default Gateway: 195.166.128.193(pppoa0) )
Tonight again im having issues with BF3 .. getting pings from 20-100 jumping up and down and getting orange triangles again... hope this is fixed soon otherwise i hate to say it but ill be looking for a new isp as i only use my net really for gaming.
Re: :( bad gaming
02-10-2012 9:52 PM
I have just done a command prompt bbc.co.uk ping and it is 12,12,28,15, then 12,26,30,40, then 26,11,12,13.
Re: :( bad gaming
02-10-2012 10:11 PM
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=34ms TTL=246
Reply from 212.58.241.131: bytes=32 time=28ms TTL=246
Reply from 212.58.241.131: bytes=32 time=25ms TTL=246
Reply from 212.58.241.131: bytes=32 time=33ms TTL=246
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 25ms, Maximum = 34ms, Average = 30ms
my av ping is from 20-25 in games, but tonight its jumping up and down alot.
Re: :( bad gaming
02-10-2012 10:51 PM
Try reconnected to hop onto a better gateway.
Ex-Broadband Service Manager
Re: :( bad gaming
02-10-2012 11:43 PM
Re: :( bad gaming
03-10-2012 12:06 AM
Re: :( bad gaming
03-10-2012 10:30 AM
The bbc.co.uk ping test comes back as 12 across the board, so see what tonight brings.
Re: :( bad gaming
03-10-2012 2:13 PM
