bad connection
- Re: bad connection
bad connection
13-10-2011 7:32 AM
can someone look at my connection please, for some reason over the last few days it has deteriated , web pages slow to load even more so on videos bbc iplayer and Utube , gaming is terrible continuous "Lost connectin to server"
the only thing that makes it better is to reset the router
Yes i am in master socket , not wireless enabled, no extension sockets on phone , speed tests are ok But everyting is sloooooooooooooooooooooow
cheers in advance i know someone here will help
Message 1 of 8
(1,612 Views)
7 REPLIES 7
Re: bad connection
13-10-2011 8:24 AM
Hi rongtw,
I've just ran some checks and I can't see anything obvious. Try some of the things below. Also make sure you have no other programs running in the background.
[quote=slow speed help page]Viruses and Spyware can slow down your computer and subsequently your download speeds. There are a number of programs (such as Plusnet Protect) which can help you find and remove these from your system. Run a full virus scan to make sure your computer is ok.
If you can, try a different router or modem on your line. If this fixes the problem, your hardware is faulty and needs replacing (if you got it from us in the last 12 months, contact us for a free replacement).
If you've followed all the advice here and your speeds are still low, please use the Broadband Troubleshooter to report the problem
Jojo
Jojo
Message 2 of 8
(633 Views)
Re: bad connection
13-10-2011 9:17 AM
Cheers JoJo the router i have is new 4 weeks ago approx , i have ran "hijackthis" "malwarebytes" "CC cleaner " and AV MS security essentials and all clean ,, checked autoruns with MSconfig & SYSINTERNALS autoruns and nothing unsusual
even PN portal loads slow compared to last week , i could run bbc i player 1020p HD no probs but now it just buffers continuosly same as youtube >:(.
maybe may try a full reinstall give me summat to do lol
Message 3 of 8
(633 Views)
Re: bad connection
13-10-2011 9:22 AM
Worth getting a fault underway just in case though
Message 4 of 8
(633 Views)
Re: bad connection
13-10-2011 6:00 PM
Reading the forums it looks like theres a few people with similar probs at the momen t is BT messing about with lines ? across the road from me they are installing a new FTTC box could this be the cause ?
Message 5 of 8
(633 Views)
Re: bad connection
14-10-2011 9:36 AM
Message 6 of 8
(633 Views)
Re: bad connection
17-10-2011 6:03 PM
update , well i havent changed any setting but since sunday all have been fine back to normal must be them Gremlins messin about again lol
Message 7 of 8
(633 Views)
Re: bad connection
18-10-2011 10:37 AM
Message 8 of 8
(633 Views)
