avtivation day
- Re: avtivation day
avtivation day
05-02-2013 1:28 PM
Is today. Openreach installed the modem by 9:15 but i am still unable to connect. I keep getting an authentication error, except for 2 times when it connected, was assigned an ip and primary end, but was otherwise dead.
If this is normal how long can I expect to wait for a connection?
I have tried phoning support but keep getting disconnected after 20 minutes.
Also, the speedchecker prior to ordering estimated 67mbps but my invoice says 40mbps despite me ordering 80 / 20 unlimited. The OR guy said the connection was set to 40mbps?
Message 1 of 9
(1,138 Views)
8 REPLIES 8
Re: avtivation day
05-02-2013 1:37 PM
I thought the open reach person was supposed to check that you had a connection?
Does it say your line is active in the order tracking?
Message 2 of 9
(582 Views)
Re: avtivation day
05-02-2013 1:43 PM
I do have a connection but the PPPoE authentication fails - except for twice. The Vy modem lights indicate a connection. It seems like my account is not active at the plusnet gateway. The order status says I will receive an e-mail when my account is ready. I want to know how long it usually takes?
Thanks,
Jan
Thanks,
Jan
Message 3 of 9
(582 Views)
Re: avtivation day
05-02-2013 1:48 PM
@Jan
I've got that activated for you. Please try and reconnect to the service.
Message 4 of 9
(582 Views)
Re: avtivation day
05-02-2013 1:51 PM
OK,
I can only speak from my experience, but mine was already activated by the time the installer came round.
Although my installation was fairly late on in the day, about 430 pm
Message 5 of 9
(582 Views)
Re: avtivation day
05-02-2013 2:15 PM
Quote from: Chris @Jan
Hi Chris,
Thanks, I am connected now, although it does look as if I am on the 40/10 package, can you please check that I am on the 80/20 unlimited package as ordered?
I have tried several speedtest sites and am consistently averaging 36.5 / 8.5 mbps when the Openreach estimate before I ordered was 67mbps down?
Jan
Message 6 of 9
(582 Views)
Re: avtivation day
05-02-2013 2:59 PM
looking through the rest of the forum I notice this incorrect provisioning seems to be happening everywhere. Is there anywhere special I need to post this problem?
Message 7 of 9
(582 Views)
Re: avtivation day
05-02-2013 3:01 PM
Digicare should pick it up from here.
Message 8 of 9
(582 Views)
Re: avtivation day
05-02-2013 3:04 PM
Hi Jan,
I've placed a modify order to move you over to the correct product. This will complete tomorrow.
Let me know how you get on.
Chris
Chris
Message 9 of 9
(582 Views)
