are upload speeds capped
- Re: are upload speeds capped
20-01-2013 2:09 PM
I currently get between 330kbps and 350kbps upload speed ,but when on aol llu I was getting between 600 and 700 kbps, Im now using googles music manager ,I understand I will not get the upload speeds of fibre but a slight increase in speed would be appreciated .
Message 1 of 6
(1,060 Views)
5 REPLIES 5
20-01-2013 2:41 PM
Are you on a 21CN or 20CN service? On 21CN Plusnet will uncap your upstream on request. This is free but if you are on 20CN Max Premium which increases upstream sync speed to up to 832kbps costs £7.83 per month.
David
Message 2 of 6
(493 Views)
20-01-2013 3:32 PM
thanks spraxyt for your reply I belive im on 21cn network so I will probabily raise a ticket to ask
Message 3 of 6
(493 Views)
21-01-2013 12:00 PM
Hi hooverman,
As you're on 21CN I've placed an order to uncap your upload speed, this will complete tomorrow for you and you'll see that your upload speed roughly doubles.
Chris
Chris
Message 4 of 6
(493 Views)
21-01-2013 1:02 PM
thanks chris I assume ref spraxyt that no extra charge is made as Im on 21cn,
Message 5 of 6
(493 Views)
21-01-2013 2:26 PM
That's right, no charge....all free
Message 6 of 6
(493 Views)
