anyone help with my sync rate.???
- Re: anyone help with my sync rate.???
21-04-2008 2:08 PM
Hi,ive just had 3 days of a lower sync rate of 1500 instead of 2000,i finally got it back to 2000 this morning and everything was back to 2000 normal.My wife then decided to clean polish and hoover,hence my power was shut down and even though im still on 2000,it showed my speed at 1856 on the router,it has cut me down from around 1890ish speed to a1500+ish,can anyone help please.Hope you can understand that lot.
regards ray.
When this happened a few days ago i went through the cust services and they said normally jameseh could do a tweak but only if your plusnet speed was showing at 2000 not 1500 and they advised me that i would just have to restart my netgear 1 time a day.This prob at the moment is different because my plusnet speed is 2000 not the 1500,so in that case can someone tweak at your end and save another 3 days of messing about.
regards ray.
Message 1 of 4
(1,418 Views)
3 REPLIES 3
21-04-2008 2:41 PM
Why not phone PN to see if they can provide a fixed rate 2 Mbits connection?
ie You could come off the MAX product and avoid all this BRAS profile nonsense.
Message 2 of 4
(501 Views)
21-04-2008 2:55 PM
Thanks for that thought mate,its just ive basically had no probs with my speeds before and im not sure why my speeds went down in this last 4 or 5 day period.Everything was back to normal and my router was restarting at 3500+ and then after it settled down it would dop to maybe 2750ish or a little lower but always i have had a rock solid 2000 plusnet speed.Ive just restarted my router again like jameseh once told me to do a long while back and my speeds were back to the 1850+ish,of course the bt technology has probably said ah! this cant be stable,but it bloody well is,i thought someone from plusnet would have picked it up but i must have been a bad boy,they dont seem to want to get involved this time.regards and i will keep that in mind,what you spoke about thanks mate.regards ray.
Message 3 of 4
(501 Views)
21-04-2008 7:12 PM
Sorry, the appropriate profile for a sync at 1856kbps is 1500kbps according Mr BT Wholesale. When BT W send the appropriate delta report to PlusNet the portal setting will change to match.
You need to sync at 2016kbps (for 3-5 days) to achieve more.
David
Message 4 of 4
(501 Views)
