any admin on ?
- any admin on ?
Re: any admin on ?
26-11-2010 6:05 PM
plus id like the line checking
Re: any admin on ?
26-11-2010 6:14 PM
Re: any admin on ?
26-11-2010 6:25 PM
Ditto what Jim said. And I certainly wouldn't welcome an engineers visit if you hadn't tried it in the test socket.
Jojo
Re: any admin on ?
29-11-2010 6:44 PM
cannot get a speed over 1400kbps and noise margin st 9db
any updates on my fault please jojo
jim:quote
Re: any admin on ?
30-11-2010 9:54 AM
No further updates as yet, will try to nudge someone in a bit about it. Your sync rate is now 1248k, SNR 9dB and Profile 1000.
Jojo
Re: any admin on ?
30-11-2010 10:09 AM
profile is usually 2000 ........ would it be worth a reset and snr set at 6db ?
router has be in test socket for well over 100hrs now so your techie guys(or dolls ) should be able to get a better picture hopefully
snipper
Re: any admin on ?
30-11-2010 10:42 AM
I can try a reset if you like, but there's no guarantee that'll be the cure, or that the SNR won't go up again. Your call though.
Jojo
Re: any admin on ?
30-11-2010 11:37 AM
Re: any admin on ?
30-11-2010 6:38 PM
i was told to try another router which i have allready
but i swapped it over like a good boy and now connected at 416kbps ans a snr 7db
Re: any admin on ?
01-12-2010 9:47 AM
I'll find out today from the faults guys what the next step is.
Jojo
Re: any admin on ?
01-12-2010 10:15 AM
i rang back support last night jojo
swapped the router back over and it sync'd at 1670 .... wiggled the test socket .. re sync'd at 800 .....
tried a re sync a few times after wiggling test socket and it sync'd at a different speed every time except when i didnt touch it and it sync'd at the same speed
so looks like a faulty master socket ( fingers crossed ) ......... just awaiting a call back from PN faults team
snipper
Re: any admin on ?
01-12-2010 12:50 PM
Not sure if they've spoke to you but one of the faults team have raised your issue to our suppliers and updated your ticket to that effect.
Jojo
Re: any admin on ?
02-12-2010 9:55 PM
line ip at the moment is 350kbps
been connected for a couple days so should lift soon to tide me over till i get the master socket done ......
Re: any admin on ?
03-12-2010 10:48 AM
I've just checked and it's still 350, but your line is really steady now so it shouldn't be too much longer. I'll check a bit later for you.
Jojo
Re: any admin on ?
03-12-2010 5:05 PM
