another slow speed
- Re: another slow speed
another slow speed
05-04-2011 2:25 PM
hi, I have just sent a message via the support page on plusnet's site (41413729) , then came here and saw another report of slow speeds since last week's outage which was cured v.quickly - not sure now whether anything could be done from here? My noise margin is 21 db up, 15 db down, attenuation is 36 db down, 10 db up; speedtest.net shows down 0.34 and up 0.38 (I also can't use the bt speedtest site). I switched off the router for one hour yesterday, no change. I plugged in to the test socked today - no change. Grateful if something could be done.
Message 1 of 7
(1,081 Views)
6 REPLIES 6
05-04-2011 2:58 PM
Hi Laura,
Are you still in the test socket?
Jojo
Jojo
Message 2 of 7
(640 Views)
05-04-2011 3:31 PM
hi Joanne, thanks for replying. No I'm not currently in the test socket. Unfortunately it means moving the laptop to the hall and then moving a cabinet! (The glimpses you must get of user's lives is making me giggle at the mo!) If you would like me to go back to the test socket I will, but is it ok if I do that tomorrow am, and then post to say that I am connected to the socket?
Message 3 of 7
(640 Views)
05-04-2011 3:52 PM
HI Julie,
Thanks for your time. I think I may be able to resolve it. Give me half an hour and I'll get back to you.
Jojo
Jojo
Message 4 of 7
(640 Views)
05-04-2011 4:33 PM
HI Julie,
Think we're sorted. Profile up to 6000k. You should see that within the next 15 minutes.
Jojo
Jojo
Message 5 of 7
(640 Views)
05-04-2011 4:45 PM
hi Joanne, I have already seen an increase in download speed, any idea what the problem was? Many thanks for your prompt help with this, I will keep an eye on the situation and will close the question I opened earlier on the support page.
kind regards
Julie
kind regards
Julie
Message 6 of 7
(640 Views)
05-04-2011 4:49 PM
The profiles at the exchange were in conflict and you were getting the lowest of the 2 profiles. I rectified that and reset the line. It sometimes works and sometimes doesn't. I'm glad it did though
Message 7 of 7
(640 Views)
