ah [Removed]
- ah [Removed]
ah [Removed]
05-04-2008 1:32 AM
Everything is up and running andworking fine.
I have a laptop in another room and i want to use my broadband connection with plusnet so that i can surf from either computer.
I stick one end of the phone cable into my microfilter and the other end into my laptop.
what do i do next pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeee.
cp:red Please do not attempt to swear in the title, see link:rules mod:end
Re: ah bollox
05-04-2008 1:53 AM
A more common way of sharing connections nowadays is for a wireless ADSL router (e.g. Netgear DG834G) of which the phone line from microfilter connects to the modem part of the router. Then you either connect via a wired Ethernet connection from the 4 port switch on the router or via a wireless connection (802.1b/g up to 54Mbps).
The other way of sharing a connection, and presumably you have Windows XP operating systems, is to use the Internet Connection sharing mechanism where the PC connected to the microfilter acts as a gateway for other users.
If you could expand on the exact setup you have it would be easier to help though.
Re: ah bollox
05-04-2008 7:33 AM
First, what ADSL equipment do you have?
You normally have 2 possible options but this may involve buying another router:
1) Connect the laptop via a wired Ethernet connection
2) Connect the laptop using a wireless connection.
Until we know what ADSL equipment you have we can't say how you can connect the laptop to your broadband connection.
Re: ah bollox
05-04-2008 9:17 AM
If so its the standard voyager 210.
The pc is running windows xp and the laptop is vista.
When i asked support about this they said i didnt need to buy anything else,but that doesnt sound right to even a thicko like me
Thanks in advance
Re: ah [Removed]
05-04-2008 9:26 AM
Welcome to the forums, but could I ask that you keep language family friendly, and not use disguised swear words in thread titles.
Jonathan
Re: ah [Removed]
07-04-2008 2:12 PM
Voyager 210 setup guide
Home Networking guide
Wired Networking guide
Wireless Networking guide
Hardware setup guides
Re: ah [Removed]
07-04-2008 2:43 PM
You cannot connect the USB port to the laptop as it won't work on Vista.
So connect the USB port to the XP machine then connect the network port to the Vista machine
You will need to buy a network cable which is long enough to reach the laptop
Re: ah [Removed]
07-04-2008 2:56 PM
Re: ah [Removed]
07-04-2008 2:57 PM
You could aslo add a wireless access point such as this which plugs into your router and will add wireless capability (or buy a wireless router and ditch the 210) allowing you to connect wirelessly as hulls has suggested.
Re: ah [Removed]
08-04-2008 12:34 PM
It doesn't include the step of actually connecting the router to the PC. (or of installing the drivers if using USB)
No wonder new users get confused.
I looked at the pdf version of the guide and the missing info is in there. How did it get left off the html version?
Re: ah [Removed]
08-04-2008 5:34 PM
Anyone got any advice on make etc for a beginner?
Re: ah [Removed]
08-04-2008 9:25 PM
Re: ah [Removed]
09-04-2008 6:52 AM
Re: ah [Removed]
10-04-2008 12:30 AM
Quote from: gofaster No wonder new users get confused.
Oooh really? I'll get *that* sorted I promise you that.
