adsl router syncing problems
- adsl router syncing problems
16-09-2007 9:50 AM
appreciate it
Re: adsl router syncing problems
16-09-2007 12:29 PM
Hope this helps,
16-09-2007 2:39 PM
16-09-2007 2:56 PM
16-09-2007 3:02 PM
Are you sure you have eliminated all possible causes within your own wiring as suggested earlier?
16-09-2007 3:58 PM
16-09-2007 6:30 PM
Quote from: orbrey I've passed this back through to the faults team for you, there should be an update by the end of the day.
hi,
the problem is not the disconnections of the modem, becuase i am just rebooting the router. The problem is that the bt line is not syncing up at the correct speed it (7800kbps),as it was for the past 2 and half years. its only syncing at 4064kbps.
ADSL Link Downstream Upstream
Connection Speed 4064 kbps 448 kbps
Line Attenuation 25 db 5.5 db
Noise Margin 9 db 25 db
16-09-2007 6:51 PM
I would recommend leaving the investigation as one of intermittent sync, as a speed fault will not be investigated by BT.
17-09-2007 8:38 AM
thanks for the recommendation, i dont think i will persue this.
However i have been thinking, on the 9th of september a transfer took place my phone line is now supplied by talk talk, HOWEVER my line rental is still with BT (Option 1). Could this have caused the problem? Previously i was on talktalk i was still getting 8meg then i moved to BT option 3 now i have moved back.
thanks
17-09-2007 9:21 AM
An intermittent sync problem would potentially cause you to receive extremely poor speeds as the chances of you having a slow resync event would be higher. Once the intermittent sync fault is fixed, speeds should return to normal within a few days.
17-09-2007 9:55 AM
Quote from: James If you line had been fully unbundled with TalkTalk you would have a connection with us at all, so I don't think that this is the cause of the problem.
hi sorry to sound stupid but how would the intermittentant sync fault be fixed? would it be corrected on the bt side of things or would it be down to me?
thanks
17-09-2007 9:59 AM
If you wish us to continue the investigation with BT, then we would need to do this as an intermittent fault and based on the assumption that it isn't your hardware causing the problem, then it would be BTs responsibility to fix this.
17-09-2007 10:06 AM
but before any of this goes any further i need to check again my hardware. i'm pretty sure its not the hardware.
what would be the next step when the fault has been reported to bt as intermittant?
17-09-2007 10:28 AM
We would send it to BT. BT would run various tests on your line and if they were unable to find a fault, the next step would be to send an engineer to visit you.
17-09-2007 10:37 AM
Quote from: James Hi again,
hi,
i have just unplugged all the phones and connected the modem router to the master socket. before connecting it to the master socket the speed was syncing at 4400kbps but now its at 6500kbps. but is should be syncing at 8000.
