adsl broadband slow
adsl broadband slow
I am getting slow broadband speeds sub 2Mbps kind of slow. I have tried connecting via ethernet, replacing filters etc.
1 - Product name: Plusnet Router
2 - Serial number: N7151871B002067
3 - Firmware version: 7.275.2_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 06:20:23
7 - Data rate: 101/1760
8 - Maximum data rate: 108/1912
9 - Noise margin: 6.2/5.9
10 - Line attenuation: 57.6/57.0
12 - Data sent/received: 31.9M/352.7M
20 - Broadband username: ******@plusdsl.net
21 - Wi-Fi network/SSID: PLUSNET-TGH69X
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: Automatic (Smart Wireless)
25 - Firewall: Default
26 - MAC Address: 8c:10:d4:27:d5:f0
27 - Software variant Version 1.0
28 - Boot loader: 7.275.2
Tags (2)
3 REPLIES 3
Fixes: 391
Re: adsl broadband slow
Our tests are showing a external fault on your line which we've raised to our suppliers.
We should have a update by the end of Tuesday at the latest.
 Matthew Wheeler
Is there any update on this?
Fixes: 391
It looks like they need access to your property to get the fault fixed.
Can you respond to the text that's just been sent?
 Matthew Wheeler
