adsl 1 or adsl 2
- adsl 1 or adsl 2
Re: adsl 1 or adsl 2
14-11-2014 12:40 PM
Estimated line speed:
3.0Mb (This may vary between 2Mb and 5.5Mb) - Checked on 2014-11-13 13:05:01
Current line speed:
2.5 Mb
14-11-2014 12:41 PM
14-11-2014 12:45 PM
14-11-2014 12:51 PM
14-11-2014 12:54 PM
14-11-2014 12:57 PM
Information
Product Name: TG582n
Serial Number: xxxxxxxxxxx
Software Release: 10.2.2.B
14-11-2014 12:59 PM
DSL Connection
Link Information
Uptime: 0 days, 0:11:45
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 440 / 4.032
Data Transferred (Sent/Received) [MB/MB]: 1,22 / 5,89
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 32,2 / 54,0
SN Margin (Up/Down) [dB]: 17,4 / 6,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 17.096
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
14-11-2014 1:03 PM
14-11-2014 1:14 PM
14-11-2014 1:18 PM
14-11-2014 1:56 PM
14-11-2014 2:58 PM
Did 'Chris' place the order for uncapped upsteam ?
Can 'Chris' also check whether the Plusnet "Current line speed" profile needs updating with this new higher download sync speed ?
14-11-2014 3:24 PM
DSL Connection
Link Information
Uptime: 0 days, 2:36:38
Data Transferred (Sent/Received) [MB/MB]: 21,34 / 96,09
SN Margin (Up/Down) [dB]: 17,6 / 6,8
Error Seconds (Local/Remote): 27 / 0
FEC Errors (Up/Down): 0 / 208.688
CRC Errors (Up/Down): 0 / 33
HEC Errors (Up/Down): 0 / 97
14-11-2014 3:52 PM
I'm glad the firmware upgrade has gone Ok,and the stats are looking quite good at the moment, errors so far are much better.
I'm not sure why everyone is rushing in suggesting Uncapping your upstream, I share Chris's caution. Whilst things do look better, we don't know yet whether it's stable and if there is still any line issue. Uncapped upstream has been known to make lines unstable, not common, but it has happened.so I would wait a while.
It's possible your line was "disturbed" - maybe the connections in the Cab had got yanked around with the Fibre work that is going on with nearby neighbour installs. It might be an issue caused by additional cross-talk as a result of the new Fibre connections. If the latter,I would hope that this firmware upgrade would resolve that.
Is you phone plugged in now? I really don't see any point in you being inconvenienced by it not being plugged in now, and it not being there may possibly mask an issue.
@Chris
Has a copper line test been carried out and shown any issues that will need to be progressed with the line provider?
14-11-2014 3:59 PM
i am keeping a close eye on it to see if anything does drop.....which maybe around peak time when people come in from work.
