add a new mailbox problem
fistsbs
I have just tried to add a new mail box, but it don't work. Sad
error message:
Invalid password, please read the instructions below
Is it just me or plus net problem ?  Huh
9 REPLIES 9
Penny
Fixes: 8
Re: add a new mailbox problem
Quote from: fistsbs
... Is it just me or plus net problem ?  Huh
From the PUG site (for all PlusNet/Force9/MetroNet/FreeOnline customers) there look to have been some recent issues with mailboxes (see for example thread starting at http://usergroup.plus.net/forum/index.php/topic,4686.0.html , from 19-21 April).
With regard to actual mailbox set-up, John Elvin kindly gave me some step-by-step instructions (I'm not very clued-up on the technological stuff) at http://usergroup.plus.net/forum/index.php/topic,3915.msg48834.html#msg48834 .
If the problem's with whatever you did on setting up the mailbox, that may well help Smiley  did for me, anyway, because I couldn't quite figure out what to do from whatever it said on the portal.
Regards,
Penny.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
bobpullen
Fixes: 316
Quote from: fistsbs
error message:
There aren't any problems as far as I'm aware. Could it be that you're attempting to use a password that's too long or contains characters that the system does not accept?
fistsbs
12 characters long password don't work, now using 8 characters long password.
jelv
Fixes: 10
Oops - that's an oversight! No guidance about the format of passwords on the mailbox creation page. Edit a mailbox and it does give the correct information.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HSNetwork
I thought 8 characters lphanumeric was all that is accepted by the PN systems and servers?
jelv
Fixes: 10
It is - but elsewhere it says that on the page where you create the password. When adding a new mailbox it does not.
bobpullen
Fixes: 316
John,
We raised this as problem 42164.
HSNetwork
Quote from: jelv
Ah, I see. Its been goodness only knows how long ince ive used the plusnet mailboxes. Only thing I had to do was use the finger command when my mailserver was being rebooted or if my connection went down for any reason.
fistsbs
If you edit the password, then still only 5 to 8 characters long.
You also can not have Upper case letters (A -Z)  Huh
