add a new mailbox problem
- Re: add a new mailbox problem
22-04-2007 10:10 AM
error message:
Invalid password, please read the instructions below
Is it just me or plus net problem ?
22-04-2007 10:55 AM
Quote from: fistsbs I have just tried to add a new mail box, but it don't work.
... Is it just me or plus net problem ?
From the PUG site (for all PlusNet/Force9/MetroNet/FreeOnline customers) there look to have been some recent issues with mailboxes (see for example thread starting at http://usergroup.plus.net/forum/index.php/topic,4686.0.html , from 19-21 April).
With regard to actual mailbox set-up, John Elvin kindly gave me some step-by-step instructions (I'm not very clued-up on the technological stuff) at http://usergroup.plus.net/forum/index.php/topic,3915.msg48834.html#msg48834 .
If the problem's with whatever you did on setting up the mailbox, that may well help did for me, anyway, because I couldn't quite figure out what to do from whatever it said on the portal.
Regards,
Penny.
23-04-2007 1:44 PM
error message:
There aren't any problems as far as I'm aware. Could it be that you're attempting to use a password that's too long or contains characters that the system does not accept?
23-04-2007 7:21 PM
23-04-2007 10:48 PM
24-04-2007 11:39 PM
24-04-2007 11:44 PM
25-04-2007 12:26 PM
We raised this as problem 42164.
25-04-2007 12:57 PM
Quote from: jelv It is - but elsewhere it says that on the page where you create the password. When adding a new mailbox it does not.
Ah, I see. Its been goodness only knows how long ince ive used the plusnet mailboxes. Only thing I had to do was use the finger command when my mailserver was being rebooted or if my connection went down for any reason.
25-04-2007 8:08 PM
You also can not have Upper case letters (A -Z)
