access to www,adobe.com
- access to www,adobe.com
23-08-2008 4:01 PM
I have completed virus/spyware scans which are all clean (on 4 differing PCs. XP home and Vista.
I have tried to connect to the site with no firewall enabled (no success).
I can tracert and ping the site.
I have tried different browsers on different PCs.
the site is available via a proxy server (and a local unsecure wireless network! - different ISP by the look of the IP address)
I have tried different DNS settings (OpenDNS as well as Plusnet).
There are a number of reported issues with this site on the web but no definitive solution.
There are previous community pages referencing this issue but no firm solution.
I have tried lowering MTU settings.
Could the broadband interleaving setting have any impact?
Does anyone else have a similar problem or resolution?
An alternate address for adobe (http://192.150.18.61/) loads the first page no nothing at a lower level i.e. any link on it!
The plusnet techies have used my IP address and all appears fine at their end which implies it has to be the line or BT voyager.
Any suggestions welcome.
Regards,
Photoart
Re: access to www,adobe.com
23-08-2008 4:13 PM
23-08-2008 4:16 PM
Quote Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>nslookup www.adobe.com
Server: ptn-cdns02.plus.net
Address: 212.159.6.10
Non-authoritative answer:
Address: 192.150.18.101
Aliases: www.adobe.com
C:\>
23-08-2008 4:26 PM
C:\Documents and Settings\Andrew>nslookup www.adobe.com
Server: voyager.home
Address: 192.168.1.1
23-08-2008 4:33 PM
23-08-2008 4:50 PM
C:>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
C:>nslookup www.adobe.com
still no sucess in getting a response though!
23-08-2008 7:02 PM
Configure your settings like in the attached screengrab, save the changes and then try again.
23-08-2008 11:24 PM
I'm able to ping and tracert, some hops are a little slow.
Regards
Photoart
C:\>ipconfig /all
Host Name . . . . . . . . . . . . : PHILIPS
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth
ernet NIC
Physical Address. . . . . . . . . : 00-11-5B-A5-0A-35
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : BT Voyager 1040 PCI Adapter
Physical Address. . . . . . . . . : 00-90-96-F2-1B-1E
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 212.159.13.49
208.67.222.222
C:\>ipconfig /flushdns
Server: pth-cdns01.plus.net
Address: 212.159.13.49
C:\>
24-08-2008 9:29 AM
No loading the page at all could be a DNS issue, or it could be a server issue too.
www.adobe.com is NOT the same site as adobe.com (i.e. different web pages are downloaded) and they do not have the same IP addresses. adobe.com resolves to 192.150.18.117, while www.adobe.com (and its canonical name www.wip3.adobe.com) resolve to 192.150.18.101 (from my machine, at this point in time).
HTH.
24-08-2008 10:07 AM
24-08-2008 10:23 AM
24-08-2008 10:46 AM
Any advice welcome.
Photoart.
24-08-2008 11:57 AM
To introduce. some lightness to all this high power stuff, earlier posts of mine concerned my inability to connect to www. adobe.com I suffered with Win 98SE with crashes whenever I tried to access any website which uses Flash. This was diagnosed as the result of having more than one version of Flash on board. I duly cleared these out as recommended. Trying to access www.adobe.com contiues to crash, presumably from the lack of any Flash...stalemate!
I wish you well with the reason for the post, it is all too far above my head for me to understand just now!
colintivy :]
24-08-2008 6:11 PM
Given colintivy's comment I wonder if this is a problem with Flash on your machines?
24-08-2008 9:18 PM
Thanks for the article I'll give it a try. I don't think flash is the issue as I have connected to www.adobe.com via a local unsecured netweok (I don't make a habit of it I just wanted to see if the page loaded). I'll disable the flash plugin and check in anycase.
I'll post an update once I've tried the Microsoft tweak.
regards
Photoart
