ZERO difference in speed following conversion to ADSL2+
- ZERO difference in speed following conversion to A...
- « Previous
- 1
- 2
- Next »
Re: ZERO difference in speed following conversion to ADSL2+
16-02-2010 11:04 PM
Quote from: magicshoes I'll need to sort out my internal wiring, leave the router up and running and see if the line profile improves, is this the right course of action.
Yes, if it's in the Test Socket.
The "line" will not improve, but you CAN improve your own wiring.
IF the problems (as is likely) are down to your internal wiring THEN the noise margin will drop and the speed improve.
The IP Profile will follow, lagging a few days, so don't get impatient.
That's the good news.
The bad news is that this (noise margin adjustment) takes weeks (or months).
I note that your speed is already approaching the earlier 13mbps estimate.
And this is almost all down to your own wiring and was there before ADSL2+.
(try's to avoid, along with others, entering "I told you so" mode)
PS: Ask PlusNet to remove your Upstream cap and you'll get 1300kbps not 448kbps.
Message 16 of 20
(265 Views)
20-02-2010 11:03 AM
You guys!
Thank you.
I have been improving my wiring, i was originally using an extension lead that had the bell wire cut but further inspection of My master socket and I have another extension wired in which you can trace once you take the Master socket face plate off.
I brought a cheap BT Iplate from Amazon marketplace and now my router syncs at:
9688 kbps / 448 kbps whilst plugged in via a new microfilter to the Iplate.
I may get the extension socket removed but for now I'm happy that I have doubled my speed but just need be patient in waiting for the Line profile to increase and the Noise Margin to be adjusted as HPsauce mentioned. I have also asked Plusnet to remove the upstream cap.
Thanks again
Message 17 of 20
(265 Views)
20-02-2010 1:25 PM
We'd be interested to see the router stats now.
Message 18 of 20
(265 Views)
20-02-2010 7:46 PM
here you go:
noise margin upstream: 33 db
output power downstream: 20 db
attenuation upstream: 17 db
tone 0- 31: 00 00 00 02 34 55 66 67 77 77 77 76 66 55 43 20
tone 32- 63: 07 88 89 aa ba ab cb bb bb bc bb bb bb bb bc bb
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 11 db
output power upstream: 12 db
attenuation downstream: 33 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: bb bb ba ba aa aa ba bb aa ba ab ab aa aa aa aa
tone 96-127: ab ab aa ba ab aa aa aa 0a aa aa aa a9 9a 9a aa
tone 128-159: aa aa aa aa a9 a9 aa aa a9 99 9a a9 99 a9 99 9a
tone 160-191: 87 99 99 8a 99 98 a7 98 9a 99 99 99 99 a9 89 99
tone 192-223: 99 99 98 99 57 88 98 89 99 98 87 86 99 96 86 87
tone 224-255: 74 57 88 99 99 87 78 78 78 67 67 79 77 86 54 67
tone 256-287: 76 45 65 54 86 65 66 75 41 22 44 43 24 35 66 25
tone 288-319: 26 42 45 34 55 44 55 42 43 64 66 64 66 62 52 43
tone 320-351: 32 22 34 24 23 23 02 44 42 04 44 25 33 12 54 44
tone 352-383: 44 42 20 22 32 41 32 22 21 12 22 22 22 44 44 42
tone 384-415: 24 22 44 42 22 22 32 22 22 32 22 22 22 22 22 20
tone 416-447: 12 22 21 12 22 12 22 12 22 22 22 11 12 10 11 11
tone 448-479: 11 00 01 11 11 10 00 00 00 00 00 00 00 00 00 00
Message 19 of 20
(265 Views)
20-02-2010 7:58 PM
Now you just have to wait.........
Unless you can persuade PN that you've fixed a "major" problem and get them to restart the training process......
Message 20 of 20
(265 Views)
- « Previous
- 1
- 2
- Next »
