Your average speed drop post AGAIN!
- Your average speed drop post AGAIN!
Re: Your average speed drop post AGAIN!
30-12-2011 8:34 AM
but this is a list of DSL codes
DSL technologies
Standard
ADSL ANSI T1.413 Issue 2
ITU G.992.1 (G.DMT)
ITU G.992.2 (G.Lite)
ADSL2 ITU G.992.3
ITU G.992.4
ITU G.992.3 Annex J
ITU G.992.3 Annex L
ADSL2+ ITU G.992.5
ITU G.992.5 Annex M
HDSL ITU G.991.1
HDSL2
IDSL
MSDSL
PDSL
RADSL
SDSL
SHDSL ITU G.991.2
UDSL
VDSL ITU G.993.1
VDSL2 ITU G.993.2
Annex version Spec Description
A xDSL over POTS xDSL service functioning over plain old telephone service.
B xDSL over ISDN xDSL Services running over ISDN Digital Phone services.
C xDSL in ISDN xDSL System operating in the same cable as ISDN as defined in ITU-T Rec. G.961 Appendix III (Currently[as of?] not implemented)
D ATU-C and ATU-R state diagrams See Annex D/G.992.3
E POTS and ISDN-BA splitters See Annex E/G.992.3. For operation according to Annexes A,B and I, the G.992.3 requirements [applying over a frequency band up to 1104 kHz shall be met over a frequency band up to 2208 kHz.
F ATU-x performance requirements for region A (North America) F.1 Performance requirements for operation of ADSL over POTS (Annex A)
F.2 Performance requirements for operation of All Digital Mode ADSL (Annex I)
F.3 Performance requirements for operation of ADSL over POTS with extended upstream bandwidth (Annex L)
G ATU-x performance requirements for region B (Europe) G.1 Performance requirements for operation of ADSL over POTS (Annex A)
G.2 Performance requirements for operation of ADSL over ISDN (Annex B)
G.3 Performance requirements for operation of All Digital Mode ADSL (Annex I)
G.4 Performance requirements for operation of All Digital Mode ADSL (Annex J)
G.5 Performance requirements for operation of ADSL over POTS, with extended upstream bandwidth (Annex L)
I All Digital mode POTS Extending ADSL band to use the voice frequency range, 32 upstream tones for an additional 256 kbit/s upstream data rate over POTS lines.
J All Digital mode ISDN Extending ADSL band to use the voice frequency range, 64 upstream tones for an additional 256 kbit/s upstream data rate over ISDN Lines.
L Reach Extended Increases the range of the DSL service enabling the link to work at a distance of 7 kilometres (23,000 ft)
M Increased Upload speeds Upstream/downstream frequency split has been shifted from 138 kHz up to 276 kHz, allowing maximum upstream bandwidth to be increased from 1.4 Mbit/s to 3.3 Mbit/s.
30-12-2011 7:43 PM
Here is the DSL connection this is the current stats after i reset today at 7am.
Everything looks ok i guess just waiting for the speed to pop back to normal.
Link Information
Uptime: 0 days, 12:32:08
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,232 / 7,040
Bandwidth (Up/Down) [kbps/kbps]: 443 / 7,288
Data Transferred (Sent/Received) [MB/MB]: 28.34 / 286.49
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 21.0 / 36.0
SN Margin (Up/Down) [dB]: 30.0 / 8.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 7 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 58 / 4,716
HEC Errors (Up/Down): 15 / 16,156
30-12-2011 8:29 PM
Try one tomorrow at least half hour after sunrise and before about 2 pm, you might get a higher synch speed..
also you router is now reporting a slightly lower speed than this morning it was 1228/7332 now 1232/7040
30-12-2011 9:32 PM
30-12-2011 9:59 PM
30-12-2011 10:09 PM
Can you post the router stats taken immediately after the resync
30-12-2011 11:12 PM
30-12-2011 11:16 PM
Once your sync speed went up to a reasonable level your IP profile would increase - which it has - but the Plusnet mirror of it takes a bit longer at present.
The actual speed you get is restricted by the lower of the two values. In your case probably the Plusnet one
31-12-2011 1:09 AM
31-12-2011 9:40 AM
ALSO ADDED THE BT SPEED TEST JUST INCASE.
Uptime: 0 days, 0:02:05
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,184 / 7,616
Bandwidth (Up/Down) [kbps/kbps]: 443 / 7,672
Data Transferred (Sent/Received) [MB/MB]: 1.60 / 15.41
SN Margin (Up/Down) [dB]: 28.5 / 9.0
CRC Errors (Up/Down): 32 / 7
HEC Errors (Up/Down): 7 / 59
31-12-2011 11:58 AM
It will almost certainly be the reason your speed is so much slower than the IP profile. It should get updated when PN get a Delta report from BT, but this sometimes takes 12-24 hours. With it being the weekend, it's unlikely the DCT (who will manually reset the value for you) will be here for a few days, but if your Current line speed does not increase in line with your IP profile, then you should be able to call the help desk who should be able to reset it for you.
31-12-2011 12:01 PM
You can either wait for it to sort itself out (probably it will take 3 or 4 weeks) or ask for a line reset - the latter would be better via the Forums in the New Year
31-12-2011 2:27 PM
My current line speed says
"Telephone number:
0000000000 <- number taken away for privacy
Phone exchange:
SHOREDITCH
Estimated line speed:
6Mb (This may vary between 5.5Mb and 8Mb) - Checked on 2011-05-19 21:38:37
Current line speed:
2.7 Mb"
31-12-2011 11:57 PM
02-01-2012 8:25 AM
It's perfectly normal to get a few random bad results from any speed tester.
It's not normal for the speed to change unless your router drops the connection (or you cause it to do that by restarting it). What does the uptime on your router stats. say?
