Your average speed drop post AGAIN!
- Your average speed drop post AGAIN!
29-12-2011 4:14 AM
Re: Your average speed drop post AGAIN!
29-12-2011 7:24 AM
29-12-2011 10:33 AM
29-12-2011 11:31 AM
If you could post the details as per Jim's link above that'd help us to get things sorted. Regarding the router, I've had a look through the tickets on your account and can't see anywhere we said we'd send one out? If you could advise of a ticket ID I'll be happy to chase it for you.
29-12-2011 10:02 PM
"Telephone number:
000000000 <- took the number away for privacy
Phone exchange:
SHOREDITCH
Estimated line speed:
6Mb (This may vary between 5.5Mb and 8Mb) - Checked on 2011-05-19 21:38:37
Current line speed:
2.7 Mb"
i attached files to show u that somethings changed on my bt speed test. max achieveable speed is 4mb? This is outreagous when since before my max achieveable speed was 7mb? why has the max gone down? i used to get speeds upto 5mb because the max was set higher now its gone down?
[Moderator's note by Jim (Oldjim) screen shot removed as it had your phone number in it ]
29-12-2011 10:06 PM
29-12-2011 10:15 PM
29-12-2011 10:27 PM
Link Information
Uptime: 13 days, 7:11:15
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,092 / 4,228
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,096
Data Transferred (Sent/Received) [GB/GB]: 2.20 / 23.45
Output Power (Up/Down) [dBm]: 11.0 / 19.0
Line Attenuation (Up/Down) [dB]: 21.0 / 37.0
SN Margin (Up/Down) [dB]: 25.0 / 13.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 66,993 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 671 / 77,177
HEC Errors (Up/Down): 233 / 150,663
Why has everything changed after that maintenance ?
29-12-2011 11:07 PM
What appears to have happened is that the default noise margin has been bounced up from 6dB to 15dB at a guess (it might be 12dB but I doubt it)
looking at the time your router has been in sync and the very low error rates it can easily stand much higher speeds.
Can I ask you to resync the router with the exchange during the daylight hours and report the stats again
If I am correct your speeds won't change much but it will eliminate or otherwise the other possibility which is that when they were fiddling at the exchange your router resynched at a time when there were still problems and it hasn't resynched since. If this is is the case you will immediately see much higher sync speeds
As a note you will notice the very high number of error seconds - this is because this doesn't reset unless the router reboots - a resynch doesn't reset the number - and this would tend to support the idea that there were a lot of problems with the line while they were fiddling at the exchange
29-12-2011 11:13 PM
29-12-2011 11:25 PM
29-12-2011 11:28 PM
Depending on the resulting speed we will know what to do.
The options are -
1. If the sync speed is much higher with a noise margin of 6dB - leave it alone and your profile on the BT side will change almost immediately and on the Plusnet side within about 12 hours
2. The sync speed doesn't materially change with a noise margin in the 12dB to 15dB band - then you will need to ask for the default noise margin to be reset - Plusnet can do this - and this should sort the problem
29-12-2011 11:31 PM
30-12-2011 7:26 AM
30-12-2011 7:32 AM
try another reset tomorrow, but between the hours of at least half hour after sunrise and before 2.pm
