Would adding the pro to fibre unlimited stop the peak time slooow downs ?
- Would adding the pro to fibre unlimited stop the...
Re: Would adding the pro to fibre unlimited stop the peak time slooow downs ?
15-01-2014 5:54 PM
and of course the peak time jitter .there aren't really any latency spikes at other times the latency increase shown on my quality meter when i upload (blue with yellow top) is normal when uploading so im not too sure what you was referring to when you said latency spikes if it's not what I've said here ?
15-01-2014 6:15 PM
Probably a good thing you're not with VM
15-01-2014 6:48 PM
16-01-2014 10:47 AM
Ex-Broadband Service Manager
16-01-2014 12:34 PM
I'm concerned about the yellow spiking generated when downloading during peak times/times of congestion ( throughput is less than max even with multiple streams ) also what are the small blob like increases in max latency that seem to occur on quite a few ping graphs ?
These are not user activity as i have a graph or 2 that show this when my pc was turned off ,these seem to be unique to plusnet, because graphs from other isp's customers don't display them on there graphs, it's almost as if something is transferring data remotely or a speedtest ?
Also re Graph observations when connected to some GW's there are frequent red spikes (packet loss) , almost like when routing gets changed this only happens on some gateways but some of it I know is unique to the links between plusnet and the tbbqm and occasionally is down to tbb themselves
16-01-2014 3:36 PM
16-01-2014 10:02 PM
16-01-2014 10:09 PM
16-01-2014 10:12 PM
Quote from: deathtrap Also re Graph observations when connected to some GW's there are frequent red spikes (packet loss) , almost like when routing gets changed this only happens on some gateways but some of it I know is unique to the links between plusnet and the tbbqm and occasionally is down to tbb themselves
If you've got any examples, I might be able to explain them. There were 2 last night and they were to do with some maintenance where line cards were being swapped out. A couple of nights ago there were a few where one of our peering partners (LONAP perhaps?) were having problems and that seemed to affect the TBB graphs a little.
16-01-2014 10:19 PM
16-01-2014 10:49 PM
As for the red spikes ,Monday 13/01/14 saw 4 instances 5am 9am 7pm &11pm times are approximate but within the hour specified and there also some on other dates too a more pronounced spike was around 6pm on the 09/01/14 to point out just some of them ,as i said they are more frequent or visible on some GW's
17-01-2014 9:48 AM
A fault is our entry point to pointing fingers are BTW around congestion/exchange issues.
17-01-2014 3:55 PM
There are the small yellow mysterious spikes that look like activity that appear on some graphs even when only modem &router are connected ,ie no pc or other devices like in this one ,i was not at home during the period this graph covers
17-01-2014 4:00 PM
I get small yellow spikes during periods of inactivity (look at 6-8am):
If I change routers, they go away.
17-01-2014 4:10 PM
Don't know why your asus is creating lag spikes though, i'm sure there are quite a few with asus routers trhat don't get the comb effect on tbbqm graphs, so it may be something in the way its set up or being used , such as is it doing other stuff locally in your network ,or a firmware issue perhaps ,or some kind of fault even
