Woefully low speed
- Woefully low speed
Woefully low speed
06-11-2015 8:38 PM
Plusnet.
Just did a BT Speed Test and my download speed is 3.91 mbps.
My normal speed here is over 16mbps.
Please can you see what the problem is and fix it?
Thank you.
Thank you.
Message 1 of 3
(652 Views)
2 REPLIES 2
Re: Woefully low speed
09-11-2015 9:31 AM
I can't see any issues with your line that would be causing those speeds.
Profile: WBC 160K - 24M No delay (INP 0) 3dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)
Sync: 1279 (up) 19270 (down)
If the problems are continuing please report this to us at https://faults.plus.net
Message 2 of 3
(407 Views)
09-11-2015 10:21 AM
Are the slow speeds using a wired or wireless connection?
Message 3 of 3
(407 Views)
