Wireshark
jaquesaulait
Wireshark
  I downloaded WS to see what the priorities are when streaming Napster (which doesn't work); Wireshark doesn't work.  I choose Capture, then Options, then choose the interface, give the Filename 'capture' and then open Napster.  According to WS, there are no packets whatsoever, not even from nrmal Internet traffic or streaming service such as Last FM.  Why isn't it working!?
Any help, advice and guidance gratefully received, as this whole Napster thing is driving me up the wall.
Thanks.
Jack, Devon.
19 REPLIES 19
ddunford
Re: Wireshark
I've not used wireshark for a while, but im pretty sure their is an option to select the 'interface' you want to capture from. Make sure you are selecting the correct network interface weather it be wireless or wired, that could be the cause for no packet capture.
Re: Wireshark
Are you using a wireless connection? If so you need to configure wireshark with your security key and encryption type so it can unscramble the packets.
Or try with a wired connection.
jaquesaulait
Re: Wireshark
  thanks for the advice.  It's a wired router, and I've tried both available options in the Interface field - still no joy.
Re: Wireshark
You have rebooted since installing the pcap library? Sometimes this is needed.
jaquesaulait
Re: Wireshark
What's a pcap library?  I've rebooted many times since having the router.
Fixes: 10
Re: Wireshark
Part of wireshark - have you rebooted since that was installed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jaquesaulait
Re: Wireshark
Jelv,
  yes I have rebooted since installing WS.
oliverb
Re: Wireshark
Silly question maybe but was wireshark running on a different computer to the one you wanted to monitor?
First time I tried Etherial I couldn't work out why I was only seeing the computer's own traffic and broadcasts...then I realised...I was connected to a switch not a hub!
Fixes: 10
Re: Wireshark
Quote from: oliverb
Been there! It's a devil of a job getting hold of a hub when you need it!
jaquesaulait
Re: Wireshark
Only 1 PC with Wireshark - the one I can't stream Napster on!
jaquesaulait
Re: Wireshark
Does anybody know why Wireshark isn't working!? Angry
Re: Wireshark
Have you read through; http://www.wireshark.org/faq.html and the other documentation on the Wireshark site.
jaquesaulait
Re: Wireshark
Do you mean in the Wireshark app?  Yes, I've tried with and without.
Thanks.
jaquesaulait
Re: Wireshark
What's an NIC?!
