Wireless speeds
- Re: Wireless speeds
Wireless speeds
25-01-2013 9:41 PM
Hi, I recently have got fibre installed and when router is hard wired to PC I get speeds of around 76mbps, however the main reason I got fibre installed was to get high speeds on my wireless devices i.e. iPhone & iPad. I seem to only get 10mbps on these devices around the house. I have the technicolor router which was supplied by plusnet and was wondering if I upgraded router would this increase speeds for my wireless devices? If so what router would come most recommended. Thanks, tony.
Message 1 of 4
(1,342 Views)
3 REPLIES 3
Re: Wireless speeds
25-01-2013 9:51 PM
Unfortunatly the PN router has several bad reports for WIFI i have no doubt someone here may give you a few recomendations for another router
Message 2 of 4
(414 Views)
Re: Wireless speeds
26-01-2013 12:14 AM
A few have recommended the Asus RT-N56U on the forum but havent seen one myself to comment
Message 3 of 4
(414 Views)
Re: Wireless speeds
28-01-2013 12:10 PM
Hi Tony,
It might also be worth checking your <a href="http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml">wireless settings</a> and see if that helps.
Message 4 of 4
(414 Views)
