Wireless printer not connecting
- Re: Wireless printer not connecting
23-08-2009 9:52 AM
23-08-2009 10:00 AM
First of all which model of Lexmark printer do you have.
23-08-2009 10:21 AM
23-08-2009 10:31 AM
23-08-2009 10:56 AM
On a similar subject I have all sorts of devices now connected apart from my sons laptop which has a BT wireless connection utillity that overrides the usual wirless connection.
No matter what I do it will not connect.
I think it may be due to the encryption that will only allow TKIP.
Thanks for the kelp on last topic.
23-08-2009 11:01 AM
23-08-2009 3:28 PM
23-08-2009 8:07 PM
24-08-2009 8:46 AM
Quote Is there any way round it do you know
Yes, make sure your router wireless security settings are not set to 'WPA2' only. Usually there is a 'WPA+WPA2' setting or if not, a 'WPA' setting. If you're using the PlusNet TG585 router see pages 25-27 of the manual.
24-08-2009 1:19 PM
27-08-2009 8:45 PM
Currently mine has both WPA+WPA2 set up.
I presume it should work with this?
I also have use Use WPA-PSK Encryption
